tire question - TCCoA Forums
post #1 of 7 (permalink) Old 02-16-2009, 05:04 PM Thread Starter
tire question
i have an 87 tbird and i was looking at tires/rims and i need to know how wide i can go on the rear without cutting stuff
thanks
Shannun is offline
post #2 of 7 (permalink) Old 02-16-2009, 07:49 PM
moore89's Avatar
When I had my 84 TBird I was running a pair of 12.5 M/T ET's on the back for a while for track use. On the street I had a set of 17" wheels I "borrowed" from a friends mustang that he totaled, (fox platform was great) and was running 305's on the back (can you even get those anymore?) and 255's on the front. (my inner fenders were rolled but that's not very hard to do).
1990 35th Anny. Supercoupe (under construction). 1991 Supercoupe (tastefully modded). 1989 5-speed Supercoupe (modded). 2003 Yamaha YZF600R (rocket)
1989 Taurus SHO (very lightly modded, but broken again)
1967 Ford F100 2WD (460 bored .060 over, too much cam and gearing for the street).
moore89 is offline
post #3 of 7 (permalink) Old 02-22-2009, 11:21 AM
Raoul Duke
cougarcragar's Avatar
I had 255s on the back of my '88 XR7, but they rubbed a little bit on the front.
1996 Mercury Cougar XR7
cougarcragar is offline
post #4 of 7 (permalink) Old 02-23-2009, 03:27 PM Thread Starter
i was only going to put the wide tires on the back i think ill keep the stock size on the front if not go a lil skinny
Shannun is offline
post #5 of 7 (permalink) Old 02-23-2009, 03:30 PM
fast Ed's Avatar
What wheel diameter are you going to use? That will limit your choices. If you're staying with the stock 16" wheels, 255/50/16 will be your widest choice.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #6 of 7 (permalink) Old 02-23-2009, 03:32 PM Thread Starter
i was thinking of going down to 15s to get the centerline rims i want
Shannun is offline
post #7 of 7 (permalink) Old 02-24-2009, 09:38 AM
fast Ed's Avatar
Then 275/50/15 will be a bit shorter than stock, or you could go as tall as 275/60/15 if the car isn't lowered, and you really want to fill the fender.
cheers
Ed N.
fast Ed is offline
