Skinny Fronts - TCCoA Forums
post #1 of 9 (permalink) Old 02-21-2009, 09:06 PM Thread Starter
Bradley Blaze's Avatar
Send a message via AIM to Bradley Blaze
Skinny Fronts
Does any one make a skinny front wheel for drag racing to fit a '95 T-Bird, or do you have to do a hub swap to the mustang's bolt pattern? I really don't want to do that b/c I don't want to have to buy new "street" wheels"
Bradley Blaze
I'd Love to Live Life in the Fast Lane, but I'm Married to a Speed Bump
Bradley Blaze is offline
post #2 of 9 (permalink) Old 02-21-2009, 10:21 PM
sik97bird's Avatar
must guys will use a their spare tire rims. SOME, but not all
I'M BACK
97 Supercharged Ford Thunderbird with warpdrive
Check out my Gallery
vist the Man RobertP at www.robstireandauto.com
sik97bird is offline
post #3 of 9 (permalink) Old 02-21-2009, 11:24 PM
Traveler's Avatar
Just be sure to mount genuine skinny racing tires on the spare rim... can't race on a temp spare!
The ultimate would be some of those hard to find aluminum SC spare wheels.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 9 (permalink) Old 02-22-2009, 04:30 AM
Most Marks came with aluminum spares.
kustomizingkid is offline
post #5 of 9 (permalink) Old 02-22-2009, 08:46 AM
nickleman60's Avatar
I have the Mustang hub swap so I found 2 Lincoln Towncar 15" aluminum spare rims at the junkyard for $7 a piece and mounted 165/80/15 Kumho's on them.
http://www.sccoa.com/forums/showthread.php?t=105244
94 SC AUTO - $$$$ Pit
nickleman60 is offline
post #6 of 9 (permalink) Old 02-23-2009, 10:03 AM
kustomizingkid,
Were those aluminum Mark VIII spare wheels 15" or 16"?
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #7 of 9 (permalink) Old 02-23-2009, 12:16 PM
Mark VIII spare should be 16, I tried to put a 15 inch spare over my Sport brakes and they don't clear the caliper, and those are the same brakes as a Mark VIII.
Bangster is offline
post #8 of 9 (permalink) Old 02-23-2009, 12:32 PM
r429460's Avatar
I have weld draglites on my 95. I did the hub, caliper and PBR rotor swap.
The welds were 15X4. I had to grind the calipers a ton to get the wheels to fit without a hugh spacer. Now I have 1/16" spacer made out of the metal traction control things from lincolns (early 90's style). Rear axle of course. The Welds fit inside the fenders with 215/75-15 tires.
Sorry but one day I will be able to post pictures.
They fit the same way on a 94 mustang.
r429460 is offline
post #9 of 9 (permalink) Old 02-23-2009, 12:41 PM
just spares with the correct tires....
