clarification on hubcentric rings - TCCoA Forums
post #1 of 11 (permalink) Old 03-04-2009, 02:25 PM Thread Starter
Motorboatin' SOB
Headlight Cleaning Guru
big mike's Avatar
are these needed only when drilling a set of non-mn12 bolt pattern wheels to the mn12 pattern?
a hub swap would negate the use of these rings, correct?
2014 GT
1990 300ZX TT
big mike is offline
post #2 of 11 (permalink) Old 03-04-2009, 02:32 PM
Eleventeenth Gear Poster
Aaron K.'s Avatar
Not necessarily. If the center bore of your wheel is larger than the diameter of your hub (large enough to creat a small gap) you should use hubcentric rings.
The gold in the pic below is my hubcentric ring. It fills the gap between the hub and inner bore of the rim to keep everything true.
Sold = 96 Thunderbird
Aaron K. is offline
post #3 of 11 (permalink) Old 03-04-2009, 02:54 PM
r429460's Avatar
don't need them.
r429460 is offline
post #4 of 11 (permalink) Old 03-04-2009, 02:56 PM Thread Starter
Motorboatin' SOB
big mike's Avatar
understood. at first glance, i thought the rings were the black part encircling the hub, with holes for the lugs. now, it looks like just paint.
2014 GT
1990 300ZX TT
big mike is offline
post #5 of 11 (permalink) Old 03-04-2009, 03:13 PM
tbirdbrain's Avatar
nice calipers you have there Aaron,
sorry for the thread jack. back to regular programming.
tbirdbrain is offline
post #6 of 11 (permalink) Old 03-05-2009, 07:26 AM
Aaron K.'s Avatar
Thanks....wanna buy em?
Aaron K. is offline
post #7 of 11 (permalink) Old 03-05-2009, 08:17 AM
Originally Posted by r429460 View Post
don't need them.
I never used them either in the past with aftermarket wheels(but they were already drilled for the MN12 pattern, and were not hubcentric).
post #8 of 11 (permalink) Old 03-05-2009, 08:29 AM
fast Ed's Avatar
Depends on if the wheels are hubcentric or not. Most aftermarket wheels that will fit an MN12 are not. If you're using OEM Mustang wheels after a hub swap, you probably won't need them, but with aftermarket wheels you likely still need to run them ... have to measure the bore of the wheels, or ask the salesperson when you're ordering them.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #9 of 11 (permalink) Old 03-05-2009, 09:02 AM Thread Starter
Motorboatin' SOB
big mike's Avatar
ed, how do i know if they are hubcentric?
these are not mustang wheels. they do have the bolt pattern for one, though. fyi, my bird is hub-swapped.
2014 GT
1990 300ZX TT
big mike is offline
post #10 of 11 (permalink) Old 03-05-2009, 08:48 PM
fast Ed's Avatar
Measure the I.D. of the wheel hub bore, compare it to the measurement of the hubs on the car.
cheers
Ed N.
fast Ed is offline
post #11 of 11 (permalink) Old 03-05-2009, 10:03 PM
Most aftermarket wheels are made with a standard bore that accomodates many cars. The hub centric ring is usually used in all those applications to ensure concentricity.
As an example all Borbet 16" wheels use a 72.6mm bore from what I found out.
Long term tire wear and balance is best with the rings.
rm
RichardM is offline
