245/50 or 255/50 on sport wheels? - TCCoA Forums
post #1 of 18 (permalink) Old 03-13-2009, 02:02 PM Thread Starter
it's time to buy tires once more and I am looking at two different size tire the 245/50/16 or the 255/50/16 on my 16x7 sport wheels. I am planing on running the same size all the way around. Just wondering if any body has any pics of what either of these size tires look like on our cars or of any issues with either of these two tire sized.
97_tbird is offline
post #2 of 18 (permalink) Old 03-13-2009, 02:35 PM
KorpseofDeath's Avatar
Send a message via AIM to KorpseofDeath
Are these what you call Sport rims?
I believe my car suspension is stock. So here is a good look for you to check out.
I just ran outside and shot 3 quick shots for you. Shows what tires I got on my car currently.
Front : 245/50z/16 Sumitomo's
Rear : 255/50z/16 BF Goodrich G-Force
~1997 TBIRD 4.6L LX SPORT ~ Xenon Kit ~ 149K Miles ~ K&N ~ JMOD ~ Daily Driver
~1991 TBIRD 5.0L HO ~ Completely Stock ~
KorpseofDeath is offline
post #3 of 18 (permalink) Old 03-13-2009, 03:07 PM
Traveler's Avatar
I ran 255/50/16's on all four corners on my LE... and it was lowered with Eibach springs. no problems whatsoever except a burning desire to drive too fast!
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 18 (permalink) Old 03-15-2009, 07:33 AM
PCD
Confirmed V6 Nut
I've got Yokohama Avid V4s's 245/50/16 for summer driving. I wanted to go 265/50/16 in the rear, but you can't put that wide of tire on a 7" rim.
PCD is offline
post #5 of 18 (permalink) Old 03-16-2009, 07:30 AM
IMHO, the best size tire for a 16 x 7 wheel is the 235 60 16.
The problem I see with any 50 series 16” size tire is that the sidewall is too short (i.e. diameter is too small) for the wheel well, unless you go too wide for the 7" rim.
Everything I've read about tires is that you want the tread width to be at equal to the rim overall width (overall width, not the bead width, so the 16 x 7 overall width is about 8” or so) with the section width as close to the tread width as possible, while keeping the diameter reasonable.
225 60 16 (OEM): Dia: 26.6, Tread width: 6.9”, Section width: 9.3”
235 60 16: Dia: 27.3, Tread width: 8.2”, Section width: 9.2”
245 50 16: Dia: 25.7, Tread width: 8.4”, Section width: 9.9”
255 50 16: Dia: 26.2, Tread width: 9.2”, Section width: 10.2”
I think MN12’s/FN10's need a larger diameter wheel before they need a smaller one.
Not the best showing the wheels, but 235 60 16:
But just my opinions.
69 F100 LWB w/460 Engine
post #6 of 18 (permalink) Old 03-16-2009, 10:47 AM Thread Starter
Right now I have 235-55-16's and just want to go a little wider with a little more agressive look.
97_tbird is offline
post #7 of 18 (permalink) Old 03-16-2009, 01:39 PM
5.0 bird's Avatar
Send a message via MSN to 5.0 bird
I agree, but even then the car still has to be lowered some.
Matt
1986 Cougar 5.0
1989 Mk VII LSC 5 speed (sold)
1992 Thunderbird Sport 5.0 (sold)
5.0 bird is offline
post #8 of 18 (permalink) Old 03-16-2009, 08:22 PM
96sport's Avatar
245/50/16's
I had these on sport rims and eibachs. They fit fine. No rubs no scrapes.
Don't forget to consider the smaller overall diameter though.
http://www.1010tires.com/TireSizeCalculator.asp
Straightaways are for fast cars
Turns are for fast drivers
96sport is offline
post #9 of 18 (permalink) Old 03-17-2009, 07:11 PM Thread Starter
anybody using this size tire 255-55-16? Check out this thread
http://www.crownvic.net/ubbthreads/u...007746&fpart=2
97_tbird is offline
post #10 of 18 (permalink) Old 03-17-2009, 08:25 PM
Dusty's Avatar
I think I saw someone one here getting them.
The Grabber UHP is General Tire's Street/Sport Truck Summer tire developed for the drivers of performance pickups, as well as sport activity and sport utility vehicles.
I am not looking to put truck tires on my Bird.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #11 of 18 (permalink) Old 03-18-2009, 08:15 PM Thread Starter
anymore pics out there
97_tbird is offline
post #12 of 18 (permalink) Old 03-18-2009, 11:24 PM
Traveler's Avatar
255/50/16's on Sport wheels:
May she rest in peace
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #13 of 18 (permalink) Old 03-19-2009, 05:10 PM
white 97 lx's Avatar
Man that's a beautiful bird Traveler
white 97 lx is offline
post #14 of 18 (permalink) Old 03-19-2009, 07:50 PM
Rayo's Avatar
That's a nice bird Traveler..what springs were you running back when you had that?
1991 Ford Thunderbird Sport
Rayo is offline
post #15 of 18 (permalink) Old 03-19-2009, 08:31 PM
Traveler's Avatar
Eibachs, with sport shocks all around.
Thanks, I do miss her...
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #16 of 18 (permalink) Old 04-03-2009, 07:51 PM
Ohio TCCoA
Spidey2721's Avatar
so you 245/50/16's guys, what tires are you running?
Spidey2721 is offline
post #17 of 18 (permalink) Old 04-04-2009, 02:30 AM
Traveler's Avatar
I'm pretty sure the guys who are running 16's are using 255/50's not 245/50's.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #18 of 18 (permalink) Old 04-04-2009, 07:01 AM
PCD
Confirmed V6 Nut
I'm running Yokohama V4s tires in 245/50/16
PCD is offline
