Replacing Lug Studs - TCCoA Forums
post #1 of 3 (permalink) Old 03-31-2009, 09:56 PM Thread Starter
Replacing Lug Studs
My lugs got loose and broke 2 of them... How would I go about replacing them? Can you replace them?
And where can I buy a couple of nuts and studs?
1996 sport 4.6 130k and still strong.
1991 SC 3.8 project and toy.
ncoop23 is offline
post #2 of 3 (permalink) Old 04-01-2009, 11:41 AM
tbirdtess's Avatar
lugs & studs
Hello
I have T-bird studs & lugs. USED.
How many sets are you looking for?
I use over-sized lugs & studs for my race car.
They are a press fit from the back side. You can get a big punch & Hammer or
tool like a balljoint tool.
Make sure there is room to push the stud out the back.
To install: place in hole, from the back. use washers & your lug nut. Make sure you use an anti seize type lube. Also use hand tools NOT an impact gun! Tighten ALL the way.
I have A press. But the parts must come off to use it.
Paul
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #3 of 3 (permalink) Old 04-01-2009, 03:40 PM Thread Starter
Thanks, I ended up calling the steelership and they had some. Wasn't too bad just took some muscle.
ncoop23 is offline
