removing coating from wheels? - TCCoA Forums
post #1 of 10 (permalink) Old 04-20-2009, 08:30 AM Thread Starter
Earl's Avatar
I'd like to remove the paint or powdercoat or whatever the factory uses on the 15" fanblade wheels and polish them...has anyone done this?
What would you all recommend for removal of the coating? Some type of chemical?
Now what about polishing to a nice polished aluminum wheel shine?
thanks!
Earl is offline
post #2 of 10 (permalink) Old 04-20-2009, 08:49 AM
lots of rubbing I see in your future..
post #3 of 10 (permalink) Old 04-20-2009, 08:55 AM
I have done this in the past. It is a real PITA to get the stock paint off. I requires several applications of good paint stripper. When you finally get them stripped you'll need to find a professional polisher. (Many of them hang out around the larger truck stops) It will cost about $100-$250 to get them polished. I have never found a guy that will polish them with a tire mounted. Believe me you will spend a lot of time keeping them polished. The alloy that they are made from doesnt bode well in the elements. Then the center cap doesnt match. IMHO you'd be much better off just getting them chromed.
BYE2YOU
growing old is inevitable
growing up is optional
94 SC
05 PT Cruiser GT Turbo Convert
Ken Horner is offline
post #4 of 10 (permalink) Old 04-20-2009, 09:54 AM
Buckcreekbilly's Avatar
Ken,I had made a post once and no reply, maybe you can answer me then, since you seem to know. You say they CAN be chromed and if so roughly how much?
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #5 of 10 (permalink) Old 04-20-2009, 11:44 AM
Rayo's Avatar
I stripped the aluminum wheels on my F-150..I used about 6 cans of paint stripper..the aircraft paint stripper worked better though...and about 4 trips to the car wash to pressure wash the paint stripper off..They look pretty good now..compared to before with that coating peeling off everywhere..I just got a set of chrome Navigator wheels i customized for the truck..So the old wheels are coming off,and will be used for winter only..Good Luck!
1991 Ford Thunderbird Sport
Rayo is offline
post #6 of 10 (permalink) Old 04-20-2009, 12:00 PM
try some place like this...
http://www.capitalwheels.com/store/c...s.php?pageid=6
post #7 of 10 (permalink) Old 04-20-2009, 12:22 PM
Well, I talked to two platers and one polisher in my area. The results arent encouraging. The plater wants "about $100 a wheel for a clean polished wheel" (no paint etc) and the polisher wants $75 a wheel to polish them, "for a clean wheel", no paint.
BYE2YOU
94 SC
post #8 of 10 (permalink) Old 04-20-2009, 01:03 PM
Wow, 75 bucks for stock, 385 chromed !! Guess i'll leave mine stock, lol. Thanks for the link.
post #9 of 10 (permalink) Old 04-20-2009, 09:00 PM
Sodablasting will remove the factory wheel paint pretty easily. I've sandblasted a few sets using a very fine grade of sand with good results, though it will leave the surface slightly rougher than sodablasting. If you're going to spend the time polishing them, it won't really make much difference.
post #10 of 10 (permalink) Old 04-21-2009, 04:25 PM
I'd just sand/media/soda blast them.... but I have access to a blaster...
kustomizingkid is offline
