Tire Balancing - TCCoA Forums
post #1 of 11 (permalink) Old 04-30-2009, 12:49 PM Thread Starter
TRex94's Avatar
Tire Balancing
Picked up 2 new tires yesterday and noticed that 1 wheel had no weights on it, is it possible that a wheel can come out balanced without weights. The other wheel has weights, am I being paranoid or what? I'm picturing he did one wheel got distracted or went to lunch and thought he balanced both afterwards.
TRex94 is offline
post #2 of 11 (permalink) Old 04-30-2009, 12:52 PM
of course that can happen......I used to work at discount tire, and sometimes you could rotate the tire on the rim, and get a better balance.(sometimes no weight was needed)
post #3 of 11 (permalink) Old 04-30-2009, 03:16 PM
as a matter of fact most machines will tell you when you can do that and not use weights at all
Patentpending is offline
post #4 of 11 (permalink) Old 04-30-2009, 03:34 PM
I worked there over 10 years ago.....they gettin all new school tools now..
post #5 of 11 (permalink) Old 04-30-2009, 03:40 PM Thread Starter
TRex94's Avatar
so it's probably okay. I'm a worry wart
TRex94 is offline
post #6 of 11 (permalink) Old 05-05-2009, 08:10 AM Thread Starter
TRex94's Avatar
hi everyone, well it was just like i figured the tire without the weights was never balanced even though I paid for it ($10.50) each wheel, what a rip-off. The tire needed 1.5 ounces of weight, needless to say I done with that tire shop.
TRex94 is offline
post #7 of 11 (permalink) Old 05-05-2009, 08:29 AM
Lame. How the heck can you forget to balance a tire?
post #8 of 11 (permalink) Old 05-05-2009, 08:44 AM
I'm guessing they didn't charge you again, right? Terminator, people make mistakes, have you ever messed up at work? More importantly, have you ever mounted/balanced a tire. Maybe two guys were on the job, and one jumped in or out midway? Atleast they didn't scratch the piss out of a wheel, not tighten a wheel enough, run a lug on crooked, not replace the stems, leave a few old weights on, etc...
coolhandzep is offline
post #9 of 11 (permalink) Old 05-05-2009, 09:37 AM
CrystalPistol's Avatar
I have seen tires that by chance balanced out dynamically to where no weights were required.
I have also worked off duty in a tire shop and have done my own tires over the last 30+ years and when younger, worked full time there. I have friends who run shops now.
Customer takes time from work, makes arrangements to have the car there, maybe waits for it .... you do not forget to balance a tire if you want to keep working long. After the first couple of missed tires come back, owner starts keeping an eye open for a replacement, and maybe finds one after awhile. Maybe you been doing good last two weeks, then one day you come to work and find you're fired. So sad.
Man running the business needs customers, forgetting to balance a tire can easily cost you a customer and their recomendations to other potential customers ... just that quick.
CrystalPistol is offline
post #10 of 11 (permalink) Old 05-05-2009, 12:05 PM Thread Starter
TRex94's Avatar
no, I didn't get charged again, but I told him I was done with him, the last time i was there about 6 years ago it took 6 hours to get 4 tires and an alignment, the place is so disorganized, its like contolled kaos, I don't need that, thanks for your relpies.
TRex94 is offline
post #11 of 11 (permalink) Old 05-05-2009, 12:14 PM
Those sound like good reasons to never go back. Glad you got the issue resolved. Hope you find a better place for the future!
