Fitting Mustang shoes on a cat... - TCCoA Forums
post #1 of 10 (permalink) Old 05-09-2009, 04:39 PM Thread Starter
I am interested in putting a set of '07 Mustang wheels on my '96 Cougar. I know the bolt pattern is wrong and was wondering if wheel adapters would be a safe, and economical way to go. And if this is a go, will there be any clearance issues?
Also, what is the lug pattern size on the MN-12 line and what other factory wheels would bolt up to this?
Thanks in advance...
Harkness is offline
post #2 of 10 (permalink) Old 05-09-2009, 06:42 PM
Adapters are not safe and you will have clearance issues because of them. The hubswap is the ONLY way to go.
post #3 of 10 (permalink) Old 05-09-2009, 06:43 PM
bowez's Avatar
MN-12 like most FOMOCO FWD 5bolts is 5/4.25 with 38mm offset. Yes the MN-12 was designed to be FWD originally.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #4 of 10 (permalink) Old 05-09-2009, 06:46 PM
Actually the reason for the goofy bolt pattern is because our rear hubs are the same as taurus front hubs to save cost. The platform as we know it was intended to be rwd.
post #5 of 10 (permalink) Old 05-10-2009, 04:01 AM
and offset is 36mm
FunktasticLucky is offline
post #6 of 10 (permalink) Old 05-10-2009, 11:22 AM
Other cars with the same bolt pattern(I make no guarantees about offset) include:
Lincoln LS V6
Lincoln LS V8(Higher offset than V6)
Mercury Grand Marquis/Crown Vic, and Towncar
Taurus
Jaguar X and S types
Some Volvos
Ford Windstar
Ford Tbird/Merc Cougar/Mark vii
Patentpending is offline
post #7 of 10 (permalink) Old 05-10-2009, 12:02 PM Thread Starter
Thanks for the heads up on the adapters... I'm sure I can find suitable aftermarket wheels... or a set of 16" T-bird/Cougar wheels.
Harkness is offline
post #8 of 10 (permalink) Old 05-13-2009, 10:21 PM
bowez's Avatar
Lincoln LS V6
Taurus
Some Volvos
Ford Windstar
What I'm finding on them is:
5x114.3 (5x4.5)
Which is the "standard" Ford RWD car bolt pattern.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #9 of 10 (permalink) Old 05-15-2009, 03:58 PM
jco1385's Avatar
x2 on the GM and Vic being the same as the stang (4.5")
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #10 of 10 (permalink) Old 05-15-2009, 06:14 PM
You guys are correct, the new ones are 5x114.3, the old ones were 4x108 i think
