225/70-16? - TCCoA Forums
post #1 of 4 (permalink) Old 05-25-2009, 01:54 AM Thread Starter
$.25 poster
AlpineBird's Avatar
Send a message via AIM to AlpineBird
225/70-16?
Would running 225/70-16's on my sport rims cause any rubbing issues? They just seem a little tall to me. I am asking this because I have a brand new set of Goodyear Fortera light truck tires on my jeep but they are not so good on the sand, and since the bird needs tires i figured I could just throw them on instead of selling them.
'96 Alpine Bird 281ci
- Clear Corners
- DynoMax Cat-Back
- Purchased with 36,000 miles, now at 101k
- No mods planned untill it's DD life is over
1998 5.9 Limited Grand Cherokee
- Flowmaster Exhaust
- AEM Brute Force Intake
- Mopar Performance ECU
- 275hp-395ft/lbs at the crank (est.) Track results in the spring!!!
AlpineBird is offline
post #2 of 4 (permalink) Old 05-26-2009, 07:49 PM
djoc2000's Avatar
they will only be a little taller....shouldn't be a problem......check out this link
http://www.miata.net/garage/tirecalc.html
You can go as fast as your money will let you
djoc2000 is offline
post #3 of 4 (permalink) Old 06-05-2009, 05:26 PM
A good site to check tire/wheel fitment issues is...bigcustomwheels.com
Under "what fits, plugging in your car info gives factory wheel info, including offset.
Under "Sizs Guide" yuo can plug in factory settings and compare what ever sizes you may be contemplating.
delz05 is offline
post #4 of 4 (permalink) Old 06-12-2009, 04:03 AM
beg to differ... I found this the other day and think this is the coolest **** since sliced bread.
http://www.wheelsmaster.com/rt_specs.jsp
FunktasticLucky is offline
