Center Caps- Standard 15" versus SC 16" - TCCoA Forums
post #1 of 9 (permalink) Old 06-30-2009, 08:49 AM Thread Starter
Are the Thunderbird logo center caps used on the standard 15-wheels the same size as the ones used on the SC 16-inch wheels? I'd like to get the sport wheels sometime and I see them all the time on ebay but never with the center caps. Would the ones I already have on my 15's fit? They look identical, but I wasn't sure if there is a size difference.
1994 Thunderbird LX 4.6 Modern Personal Luxury Coupe
1975 Elite 460 Vintage Personal Luxury Coupe
and a few GM products...
Lyanheart is offline
post #2 of 9 (permalink) Old 06-30-2009, 09:20 AM
I have the center caps from my old 15'' fanblades on a set of 96-97 sport wheels. They fit perfect, I just use care in removing them to avoid scratching/gouging the wheel. There is no recess on a sport wheel like on an sc wheel to aid in removal of the solid cap.
coolhandzep is offline
post #3 of 9 (permalink) Old 06-30-2009, 09:58 AM Thread Starter
Excellent, that's just what I wanted to hear! Thanks
post #4 of 9 (permalink) Old 06-30-2009, 03:03 PM
The center caps are the same size between the 15" wheels, and the later 16" SC/sport wheels. However the 89-92 SC wheels use a different size center cap that is not interchangable with any other wheels.
post #5 of 9 (permalink) Old 07-02-2009, 09:49 AM Thread Starter
Oh.. well crap. How do I tell the difference between the pre-92 and post-92 if I'm looking at wheels? Or do the earlier ones look different?
EDIT:
After looking at a few of the wheels, I can see there is a difference between the pre- and post-92 SC/Sport wheels. That should make it easier. Now the hard part, as far as I can tell, is actually finding correct-sized tires. Not a lot of choices out there for the 16-inch sizes.
post #6 of 9 (permalink) Old 07-02-2009, 11:45 AM
89-92 wheels
http://sctuning.net/repository/site/tbird1.jpg
93-95 wheels
http://members.tccoa.com/rustyul/%20...ale%20mysc.jpg
Also, an easy way to tell is the 93-95 wheels are side specific, while the 89-92 wheels are all the same, so if 2 point forward and 2 point backwards when they are on the car, then they are the early style wheels.
post #7 of 9 (permalink) Old 07-02-2009, 04:27 PM
EDIT:
Here you go, you have 88 choices.
http://www.tirerack.com/tires/Compar...10&RunFlat=All
Steve
S_Mazza is offline
post #8 of 9 (permalink) Old 07-02-2009, 07:34 PM Thread Starter
Haha, thanks. I don't know what I was looking at before but I didn't see nearly that many. I was hoping to find more variety in wider-than-stock sizes, too. I guess that's where the trouble starts.
Too bad my 275/60/15's from my Elite won't work for the Thunderbird! :-P
post #9 of 9 (permalink) Old 07-06-2009, 02:16 PM
Haha. Those miiiight be a little off.
On a serious note, I just bought new tires in the stock size. I don't need winter capabilities since I have 15" snows already, and I wanted something with decent ride and treadlife as well as good handling. (Mostly looked in the Grand Touring class.) I went with Michelin Primacy MXV4s, and so far, they are great. Really smooth and quiet, but have a good handling feel. They are a little expensive (like $130 each), but there is a $60 rebate on a set of four (at least when I bought them).
Steve
S_Mazza is offline
