235-70-15 ???? - TCCoA Forums
post #1 of 13 (permalink) Old 07-11-2009, 05:24 PM Thread Starter
235-70-15 ????
was curious if anyone had ran this size,
Looking to fill up the wheel well
i'm trying to decide between 225-70-15, 235-60-15 or 235-70-15
transam396 is offline
post #2 of 13 (permalink) Old 07-11-2009, 06:40 PM
The 235/60 is shorter than a stock 215/70/15. The 235/70 is about 28 inches tall. If you want a little more height than stock go with the 225/70. I think the 235/70 would be excessively tall and would look a little funky, though it would definitely fit in the back. The 235/70 is only a little shorter than what you typically see on a stock s-10 blazer (235/75/15).
coolhandzep is offline
post #3 of 13 (permalink) Old 07-11-2009, 07:34 PM
Buckcreekbilly's Avatar
I just ordered a set of 255/60 15 for the rear of mine. They are almost identical in height with the 215/75 15's i have on the front. When those wear out, i will go to 215/70 15's on the front which will make the back a hair taller.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #4 of 13 (permalink) Old 07-11-2009, 08:10 PM
Sideoiler's Avatar
See the difference in sizes using the link below.
http://www.miata.net/garage/tirecalc.html
Sideoiler is offline
post #5 of 13 (permalink) Old 07-13-2009, 07:54 AM
245/60 and 255/60 are both great 15" tire sizes. The 245/60's I have on the front of my Elite are just about identical in height to the 215/70's currently on my Thunderbird. Problem is wheel width. I wouldn't want those tires on anything less than a 7-inch wheel, and the stock T-bird wheels are only 6 inches. 255-width tires should definitely be on a wider wheel. Guess you'll just have to see how it turns out. It might work OK, you'll just have a lot of sidewall bulge.
1994 Thunderbird LX 4.6 Modern Personal Luxury Coupe
1975 Elite 460 Vintage Personal Luxury Coupe
and a few GM products...
Lyanheart is offline
post #6 of 13 (permalink) Old 07-13-2009, 12:42 PM
Sorry to hijack...
But I was curious.
What's the largest tire that will fit on a 7.5W 18" rim? I'm looking to swap my back tires soon.
I want something tall enough to fill up the wheel well a bit more but not so much as to skid on the inside of the wheel well on a bumpy road.
Same with width, the widest tire that will fit on without looking like the tire is about to pop off the rim.
- Painted the upper body line Metallic Gold
- 20% Tint back/35% up front
- 18" chrome Pacer VALINNs
- Air silencer delete
- Mufflers replaced w/ chrome tips
- Now retired to Daily Driver
93 Mark VIII Lemon
R0mo is offline
post #7 of 13 (permalink) Old 07-13-2009, 12:55 PM
Originally Posted by R0mo View Post
But I was curious.
A 245/45/18 is the widest recommended size for a 18x7.5 wheel and is roughly the same height as the various stock tires sizes available; slightly less than 27 inches. You can actually use wider tires without a problem, but you should get a wider wheel, such as 18x9. A 275/40/18 is about the same height as that 245/45, but a minimum of a 9-inch wheel is recommended. As sidewalls get smaller so does the tolerance of how wide a wheel you should use.
post #8 of 13 (permalink) Old 07-13-2009, 09:18 PM
Send a message via AIM to Stocker
235/70 is a bit too big to be running everyday. I don't remember what the size was on the back of the car when I bought it, but I'm fairly sure it's about the same OD. I think the front was something like a 225/60 but don't quote me on that.
1991 LX Thunderchicken
4 wheels/tires, A motor/ transmission, few seats and gauges
Yep, she's got it all
Stocker is offline
post #9 of 13 (permalink) Old 07-14-2009, 06:53 AM
coggonobrien's Avatar
i run 215/70 r15 up front and 275/60 r 15 out back on my bird
coggonobrien is offline
post #10 of 13 (permalink) Old 07-14-2009, 11:41 PM Thread Starter
I went with the 235/60/15 cooper cobras and I really like the way it looks.
The tires on the front were in horrible shape, I got them for 477 and got it align'd for 79 .
I tell yah it's like driving a new car!!
post #11 of 13 (permalink) Old 08-02-2009, 11:11 PM
Cool
Cool beans! That's what I have on mine. Cooper Cobra R/W letter tires, 235/60 on the rear, 215/60 up front for a slight rake look. Check out the gallery
Uncaged 94 is offline
post #12 of 13 (permalink) Old 08-05-2009, 09:32 AM
Street Freekz
96_Cougar's Avatar
Send a message via MSN to 96_Cougar Send a message via Yahoo to 96_Cougar
Given the choices you listed I'd go with 225/70/15. Beware, changing to a taller tire cut my gas a good bit for just 'city/town' driving but was still ok for 'open highway/trips'.
I ran 215/75/15 BFG's on mine without problem; 225/70 is almost the same height.
In Memory of FD 420
"This will remain the land of the free only so long as it is the home of the brave" ~ Elmer Davis, American news commentator (1890-1958). God bless all veterans: past & present.
96_Cougar is offline
post #13 of 13 (permalink) Old 08-05-2009, 09:36 AM
Jezz that bird looks like a 4x4
