Cobra wheel what Year? - TCCoA Forums
post #1 of 13 (permalink) Old 07-25-2009, 08:10 PM Thread Starter
Banned
Can anyone tell me what year cobra this wheel came from?
Thanks, lexx007
lexx007 is offline
post #2 of 13 (permalink) Old 07-25-2009, 09:31 PM
Aftermarket 95 cobra R
post #3 of 13 (permalink) Old 07-26-2009, 02:12 AM
Traveler's Avatar
And if you're thinking that the Mustang Wheel will fit your T-bird.... don't. it won't.
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #4 of 13 (permalink) Old 07-26-2009, 08:26 AM Thread Starter
Banned
How about a hub swap, I found an article dated 9 years ago that you can do it and I am get the parts now.
lexx007 is offline
post #5 of 13 (permalink) Old 07-26-2009, 08:30 AM Thread Starter
Banned
Hey XR7 are these worth 200 for 4 wheels with tires?
lexx007 is offline
post #6 of 13 (permalink) Old 07-26-2009, 09:15 AM
Traveler's Avatar
Yes, a hubswap is possible, in fact many on here have done it. Just do a search for "hubswap". The front is a simple install new Mustang hubs instead of T-Bird hubs. the rear you have to have Cobra hubs pressed in. And you will of course need Mustang Brake rotors for the front, and have your rear rotors re drilled. to the Mustang pattern
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #7 of 13 (permalink) Old 07-26-2009, 07:55 PM Thread Starter
Banned
Many thanks traveler I will do that
lexx007 is offline
post #8 of 13 (permalink) Old 07-26-2009, 08:37 PM
CDW6212R's Avatar
Those Cobra R's are very very common in the aftermarket. Surely someone makes them in the MN12 bolt pattern. I hear of them being had new for $400 total, but beware of those low quality wheels.
_________
Don
91 Mark VII LSC SE, Griggs and MM suspension soon
98 Mountaineer, A4WD, Big brakes - 12.75" x 1.25" rotors
CDW6212R is offline
post #9 of 13 (permalink) Old 07-26-2009, 09:40 PM Thread Starter
Banned
When I do the swap, I have most of the parts for the front end.
For the rear, I know that I have to mod the knucles ( need to know detailed info on that). I want to use the mustang hubs,rotors, and possibly the calipers on the rear.
Can you tell me what years and type mustang to use for the rear swap?
Also, I want to use ford mustang rims like the bullitt style. I was thinking of the bullitt 17X8's. I'm not to keen on the offset can you recommend me what sizes and years, etc.
Thanks so far for all the great help
Lexx007
lexx007 is offline
post #10 of 13 (permalink) Old 07-26-2009, 10:55 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
they are made in tbird bolt pattern but they aren't being made anymore so only way is used. but you might as well do the hub swap and get pbr brakes as well while you're tearing **** apart
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #11 of 13 (permalink) Old 07-27-2009, 02:17 AM
Traveler's Avatar
The Cobra Wheel is pretty common in the MN12 pattern. I used to have a set myself as a matter of fact. If you want detailed and accurate info on the wheels (or if you want to buy a set) contact Cudaz on this site. He has the custom wheel shop you see advertised in the upper right hand corner here.
And there are several threads on here about the hub swap, just gotta do a search.
Low Miles
Wifes Car
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #12 of 13 (permalink) Old 07-31-2009, 06:48 PM
kamakazie_1's Avatar
Send a message via MSN to kamakazie_1
Lexx007
Talk to Cudaz101, Brad has a killer set of the Bullet gun metal grey with a polished lip, I have the link to it here somewhere..
Here it is: http://forums.tccoa.com/showpost.php...1&postcount=16
RJ
1995 SC: Pearl white, 5Spd
2003 Ford F-350 Dually 4x4 7.3L PSD, Preditor Sport Prog.
kamakazie_1 is offline
post #13 of 13 (permalink) Old 07-31-2009, 10:52 PM
sdavis872's Avatar
sdavis872 is offline
