Wider than 15" x 8" on the rear? - TCCoA Forums
post #1 of 13 (permalink) Old 08-19-2009, 09:34 PM Thread Starter
Kurt K's Avatar
I will be getting some new rear drag wheels and I'm curious if anybody is running a 15" wheel that's wider than 8". I borrowed a 16 x 8.5" wheel to do some test fitting and it looks like anything wider than 8" will hit the upper control arm.
If you are running 15x8 or wider, what is the backspacing or offset?
Kurt K (e-mail)
"I'll either die owning this car or it will kill me."
'92 SC AOD -- 11.521s @ 116.748 mph, 2.0 AR power
. . . . . . . . . -- 13.547s @ 101.01 mph, only w/ bolt-ons
'95 SC 5spd -- All Stock, except 17" Simmons wheels.
'90 SC 35th Anny 5spd -- 3rd owner, 16k miles
2 '89 XR7 5spd's -- on their way out, really! Any Offers?
Kurt K is offline
post #2 of 13 (permalink) Old 08-20-2009, 09:18 AM
LOLA's Avatar
I'm running 18x9's all the way around with no issues. They are not drag wheels but that shouldn't make a difference.
Have you checked with Brad (cudaz101)?
LOLA is offline
post #3 of 13 (permalink) Old 08-20-2009, 09:22 AM
coggonobrien's Avatar
i'm running 5.5" back spacing with a 15x8 weld pro star. upper control arm is the limiting factor. you best bet would be to switch to a live axle with ladder bars if you need a wider wheel. that's the direction i'm going.
coggonobrien is offline
post #4 of 13 (permalink) Old 08-20-2009, 11:28 AM
If you go larger than a 15" you can fit wider than 8" width. As stated above I have also used a weld wheel with 5.5" back space with an 8" width and had very little clearance. If you go up in diameter you can clear the upper control arm
teal944.6 is offline
post #5 of 13 (permalink) Old 08-20-2009, 12:52 PM Thread Starter
Kurt K's Avatar
I was hoping to stick with a 15" drag wheel since there is a greater selection in tires, than there is with 16" wheels.
I know Brad was working with Holeshot on a drag option for us, but I haven't seen any updates for a few months.
No live axle for me. I'll have to work around the IRS because I won't be giving that up.
Kurt K (e-mail)
Kurt K is offline
post #6 of 13 (permalink) Old 08-21-2009, 06:55 PM
Hardcore TBU #5 (in tow)
Nettlesd is offline
post #7 of 13 (permalink) Old 09-26-2009, 04:00 PM
Teeps's Avatar
Yeah, definately interested in a 16x9 or 16 x 9.5 (not sure on exact clearance for backspace)
I believe diamond racing offers a 16x10 with 6" backspace for the IRS-Terminator guys. I believe they also offer a version with larger backspace, but I don't know if either will clear.
I'm running the stang bolt circle so it may be worth a try.
1997 Sport - Work in progress:>
MP BB 304 Teksid 4v- w IC'd / Ported M112
Need:
Eaton pulley puller (VMP or BF preferred)
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #8 of 13 (permalink) Old 09-30-2009, 07:40 PM
Banned
how did you get the mustang bolt circle? the 5X4.5" I was told mine on a 1995 bolt circle is a 5X4.25" I asked about an adapter to change them up from jegs and summit both and they were both a no go...
pm me more info on this please?
soprry, not trying to hijack this thread. there are several options on the 16" wheels, along with drag tires out now... migh want to double check because I also saw a lightning with a
16" wheel and an et drag tire on it, and it looked dinky on his truck...
Big Ed H is offline
post #9 of 13 (permalink) Old 09-30-2009, 08:16 PM
94-04 mustang front hubs and brakes, they are a direct bolt on. In the rear use 99-04 irs cobra hubs and redrilled tbird rotors in the rear or adapt the cobra brakes. There is a tech article on the site somewhere.
post #10 of 13 (permalink) Old 09-30-2009, 09:35 PM
Teeps's Avatar
Yes, I used cobra rotors with adapter plates to mount the calipers at a slightly different offset for the rotor.
The rear hubs have to be pressed-in; My street rims are the 98 cobra 17x8, and the offset is perfect.
Need:
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #11 of 13 (permalink) Old 10-01-2009, 04:27 AM
MY 95 HAS 16X 10 All the way around [ 90 corvette wheels with spacers 6in back spacing] and 15x 10 weld prostars for the 1/4mile.
KRUG MOTORSPORTS
57 Chevy 410ci / 66 Chevelle ss 396ci / 67 Chevy C/10 350ci / 70 Chevy C/30 8in lift 355ci / 70 Camaro Z28 406ci / 87 Mustang GT 454 ci Chevy /87 F/150 4X4 302ci /95 T-bird 281ci / 95 T-bird 281ci /06 Harley Street Bob 96ci
Deadman is offline
post #12 of 13 (permalink) Old 10-01-2009, 04:35 PM
Teeps's Avatar
Thanks!
So what size spacer?
Your rear wheel has a 6.0 back-space, without including the spacer?
Or 6.0 backspace including the spacer?
I.E. a 1/2" spacer would then change the backspace to 5.5", unless your including that in your figure.
Don
Need:
H/E
Cowl Hood
FRPS
FORE Regulator
Teeps is offline
post #13 of 13 (permalink) Old 10-04-2009, 12:43 PM
Teeps, i went out this morning and tore my wheels off and measured everything for ya.This is what i have with no rubbing problems.
95 BIRD with 90 corvette wheels i converted to GM bolt pattern, 16x10 with 6 7/16 backspacing and 1in wheel spacers . Wheels dont stick out past the fenders and they dont rubb anywhere. I had to machine the front spindle upright just slightly so the rubber sidewall fouldnt flex and rubb. The rear is a perfect fit. If you use a 15in wheel you may need to move the rear swaybar endlink. good luck with yours .
KRUG MOTORSPORTS
Deadman is offline
