mustang rims with adapter questions - TCCoA Forums
post #1 of 22 (permalink) Old 08-30-2009, 06:59 PM Thread Starter
svtfiend@yahoo.com's Avatar
I really like the bullit style stock 17" anthracite mustang rims, and you can get them cheap as hell with tires from newtakeoff.com. I know you can get adapters for them to fit our cars, does anyone know a good place to get them? Anyone have any feedback on how they look or work with stang rims? do the rims stick out funny or anything? thanks guys, i know i can get bullit replicas from the custom shop, but i just wanted to investigate all options, thanks!
1991 Super Coupe -
Performance=5.0 H.O. w/M5R2 5speed, 3.27 gears w/CF TracLoc,95 Cobra intake, 75mm Power throttle body, fenderwell CAI, C&L 73mm mass air w/24# injectors, FRPP E-Cam,Trickflow spring kit & Crane 1.7 roller rockers on stock E7s, MAC shorty headers, Flowmaster cat back w/hiflow cats, MSD plugs, coil, wires, electric cooling fan, 190lph Walbro fuel pump, BBK pulleys, and a B&M shifter. Drilled/slotted rotors, power brake conversion, Tokico Blues, Eibach springs, tons of poly, T4MO ecm
post #2 of 22 (permalink) Old 08-30-2009, 07:01 PM
Clueless Poster
v8_superbirdy's Avatar
Send a message via AIM to v8_superbirdy Send a message via Yahoo to v8_superbirdy
best place is the junkyard
my other ride is an ambulance!
1997 V8 sport - first car - sold 6/7/10
2006 silver mustang gt premiumcustom made grill, frpp shorty headers, pypes cat back exhaust, hurst billet pro shifter,
v8_superbirdy is offline
post #3 of 22 (permalink) Old 08-30-2009, 10:49 PM
Adapters=bad/dangerous.
post #4 of 22 (permalink) Old 08-31-2009, 12:05 AM
where are u gunna find an adaptor in the just yard..
btw, ebay wants $100 for 2..
Scottie6.0 is offline
post #5 of 22 (permalink) Old 08-31-2009, 09:00 AM
Nitemare's Avatar
It's called a hub swap.
Needs more stall.
Nitemare is offline
post #6 of 22 (permalink) Old 08-31-2009, 10:41 AM
If they are 05-09 wheels, then the adapters would not be thick enough to be the type that bolt to the hub and have different lugs for the wheels (which you would need for 4.5 to 4.25 adapter or do a hub swap). There are also different wheels with different specs, and OEM and aftermarket ones are different. I think with the Bullits with the euro lip (no real lip) have more backspacing than the ones with the lip it seems. MAYBE you could use an adapter with some of them.
If they are pre 05 wheels, then they already have too little backspacing, and an adapter would push them out past the fenders.
Bangster is offline
post #7 of 22 (permalink) Old 08-31-2009, 02:09 PM
Thats when you roll your fenders out to make um fit..
post #8 of 22 (permalink) Old 08-31-2009, 02:16 PM
Yea, that wont help at all in this case.
post #9 of 22 (permalink) Old 08-31-2009, 05:13 PM Thread Starter
so basically not a good idea? got it. any other input would be sweet.
1991 Super Coupe -
post #10 of 22 (permalink) Old 08-31-2009, 08:21 PM
mrwiggles2004's Avatar
I ran adapters w/ cobra r's on my bird for close to two years before I did the hub swap. I can't say I ever had a problem with safety. As long as you put thread lock on the lug bolts before you install the adapters you'd be fine. Problem is for the cost of a set of good adapters you can buy most of the parts for a hub swap.
Also, they look pretty ridiculous in the front as the adapter is going to add the thickness of itself to your offset. Rears looked kinda mean with the extra offset.
97 Thunderbird LX 4.6L
Current Mods
PI Intake Manifold, Comp XE268's, 180 degree T-stat, Brother's Performance U/D pulleys, K&N filter w custom CAI, 75mm TB and Trick Flow plenum, Borla mufflers w Magnaflow tips, Magnaflow straight cats, Summit 8mm wires, Eibach Pro Kit Springs, Koni Adjustable Front Shocks, Bilstein Cobra Rear Shocks, Cobra R replica rims(17x9)front (17x10.5)rear
mrwiggles2004 is offline
post #11 of 22 (permalink) Old 08-31-2009, 11:07 PM
bgck7's Avatar
adapter for 4.25 -4.50 fitment on ebay
hi all,
Just type in 5x4.25 on ebay and got this info for those that are interested.
regards,
ramon
http://cgi.ebay.com/ebaymotors/5X4-2...4506.m20.l1116
bgck7 is offline
post #12 of 22 (permalink) Old 09-01-2009, 12:55 AM
Yeah, for the price of the adapters and a set of Stang wheels, you could just as easily saved up and gotten the Hubs and swapped them out. Yes it's less work to do the adapters, but do you want something permanent that you don't have to worry about offset or do you want something that is temporary and IMO kind of poser like? Do it right the 1st time.
peace keeper v8 is offline
post #13 of 22 (permalink) Old 09-01-2009, 01:09 PM Thread Starter
any good write ups on the hub swap?
1991 Super Coupe -
post #14 of 22 (permalink) Old 09-01-2009, 01:30 PM
post #15 of 22 (permalink) Old 09-02-2009, 01:12 PM
Originally Posted by peace keeper v8 View Post
Good job! There's some hope for you after all!
post #16 of 22 (permalink) Old 09-02-2009, 01:13 PM
After doing the intake, I have a new found respect for the seniors on the board.
post #17 of 22 (permalink) Old 09-02-2009, 01:20 PM
just curious, but who are you reffering to as seniors?
post #18 of 22 (permalink) Old 09-02-2009, 01:25 PM
Anyone that has over 2,000 posts.
post #19 of 22 (permalink) Old 09-02-2009, 02:28 PM
That makes me old then...
post #20 of 22 (permalink) Old 09-02-2009, 03:21 PM
one thing that confuses me (one thing? theres only one?) well the current thing confusing me... after the hub swap, we still use the same offest as now, right?? then how on earth do I see these mn-12's with "deep dish" wheels without sticking them out past the wheel wells?
poomwah is offline
post #21 of 22 (permalink) Old 09-02-2009, 03:34 PM
05+ mustangs have offsets in our favor, if you want deep dish wheels with a hubswap get the ones meant for them.
post #22 of 22 (permalink) Old 09-02-2009, 04:20 PM
ahhhhhhhhh, thanks xr7 :]
poomwah is offline
