Clearence Issues With Tires - TCCoA Forums
post #1 of 8 (permalink) Old 09-09-2009, 02:46 PM Thread Starter
danalba's Avatar
ok i currently have 245/40/18 tires on 18x9 38mm offset rims. im getting new tires tomorrow and i want to go thicker with the front tires.
BUT i was told i will have clearence issues with putting anything thicker than 40 on these rims.
does anyone know if ill be able to fit anything thicker on these rims without them rubbing on the control arm or anything?
PLEASE this would be a big help. id prefer not to go the trial and error route on this one...
also will i be able to go wider?
i would like to go maybe something like 250or55/50or55/18
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #2 of 8 (permalink) Old 09-09-2009, 05:08 PM
R8D-XXX's Avatar
I am running 255/45/18 in the front of my car with no problems.....but I also have 36mm offset wheels. So yes, you could go with a wider tire but you may have to invest in some little 1/8" spacers for the front wheels.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #3 of 8 (permalink) Old 09-09-2009, 08:48 PM Thread Starter
danalba's Avatar
with those spacers you wont see a distinct difference from the back without them will you?
also what about thicker? 255/50/18? not necessarily wider?
what width are your rims? mine are 9 inches wide which is pushing it with a 38mm offset
PI intake/PI cams
355 trac lok
danalba is offline
post #4 of 8 (permalink) Old 09-10-2009, 11:37 AM
R8D-XXX's Avatar
No. An 1/8" spacer would only equal to about 3mm.
I'm running 9" wheel also with 36mm offset.
And I could be wrong about this whole thing. I'm just not sure if you can pull off a bigger tire with a 38mm offset wheel. But like I said, my wheel and tire combo is fine.
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #5 of 8 (permalink) Old 09-12-2009, 03:09 PM
Icarus's Avatar
danalba, for your info:
On a 255/50/18 tire, the 255 is the width of the tire, the 50 is a percentage of the width and equals how tall the sidewall is (50% of 255 in this case), and 18 is the size rim it's made to fit...
Ϣr
1994 Lincoln Mark VIII
4.6L DOHC; meter4it.com chase/sequential tail lights; 20" Giovanna Dalars; 4.30 gears; FRPP Track-Lok; SCT tuned; Baumann ReCal; Addco bars; Cobra brakes...
RIP - '86 Mark VII LSC
Icarus is offline
post #6 of 8 (permalink) Old 09-25-2009, 08:35 PM
carcrz's Avatar
hey R8D-XXX thats a bad ass bird you got there sir
carcrz is offline
post #7 of 8 (permalink) Old 09-26-2009, 09:46 AM
R8D-XXX's Avatar
thanks man!
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #8 of 8 (permalink) Old 09-26-2009, 04:32 PM
bgck7's Avatar
wheel spacers
Hi all,
check these out, i have these on my mark and t-bird fronts, baer spacers on ebaymotors and love em!!!
regards,
ramon
http://cgi.ebay.com/ebaymotors/Baer-...=p4506.c0.m245
bgck7 is offline
