darn weird bolt pattern - TCCoA Forums
post #1 of 7 (permalink) Old 09-10-2009, 05:25 PM Thread Starter
I just found a set of 5 spoke American Racing wheels, 16x7, with center caps, decent tires, 45 minutes away and only 80 dollars!!! they have the 10 lug holes for the dual bolt pattern. So I call the guy up, and it turns out, he took them off a beretta :[ dang it all
poomwah is offline
post #2 of 7 (permalink) Old 09-10-2009, 06:14 PM
bob9646's Avatar
And?
What is the bolt pattern of a Baretta?
What is the other bolt pattern?
I guess I don't get what you're problem is...
Shipping out to basic training for the army on april 12th!
Bird is on serious down time
bob9646 is offline
post #3 of 7 (permalink) Old 09-10-2009, 06:17 PM
Buckcreekbilly's Avatar
If the uni lug pattern fits a 4.25x5, then they're good, if not, forget it. Unless you've done a mustang hub swap on your car.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #4 of 7 (permalink) Old 09-10-2009, 06:55 PM Thread Starter
i was griping because I found the wheels I want semi local for a great price with the wrong bolt pattern.
they are dual bolt pattern for GM :[ so that would make 5x100 (beretta) and 5x115
poomwah is offline
post #5 of 7 (permalink) Old 09-10-2009, 08:08 PM
bob9646's Avatar
Oh ok. directly into the garbage.
bob9646 is offline
post #6 of 7 (permalink) Old 09-10-2009, 08:35 PM
If You do a mustang hub swap..
You can use nearly any/every rim out thier!!
Scottie6.0 is offline
post #7 of 7 (permalink) Old 09-10-2009, 08:50 PM Thread Starter
that's true, but this was the particular style of wheel I want. not to mention theres someone on this forum that has a set of them for 230 shipped. which would be a LOT cheaper than doing the mustang hub swap. lol, and I can't even afford the 230
poomwah is offline
