what can be done with stock rims? - TCCoA Forums
post #1 of 17 (permalink) Old 09-15-2009, 05:31 PM Thread Starter
Just wondering if anyone's had luck blasting and polishing -or- painting the factory rims (96-97) and if they come out good enough to be worth the hassle...
Thanks!
thunderinbird is offline
post #2 of 17 (permalink) Old 09-15-2009, 05:52 PM
It depends what style rims you have, and what kind of look you are going for, but if you take your time and do it right, a little paint can go a long way. These are stock SC wheels, painted with rattle can flat black, then clearcoat over the whole thing. All told, I probably have about $10 and 2-3 hours into all 4 wheels.
MadMikeyL is online now
post #3 of 17 (permalink) Old 09-15-2009, 06:14 PM
I used two quarts of Formbys paint stripper to get the paint off of a set of 89 wheels. Aircraft stripper doesnt do much at all. Its a really messy job. Then I drove about 100 miles to a truck stop that I am familiar with that I know has a good polish crew. They did a nice job, and they looked good. Within about 2-3 weeks they looked like poop. They were a constant PIA. If you can find something to seal them with it would help a lot. I should also warn you that the casting finish on the wheels isnt very smooth and requires a lot of cut buffing to get them to look polished. Oh, and it cost me $150 for the first polish job.
BYE2YOU
growing old is inevitable
growing up is optional
94 SC
05 PT Cruiser GT Turbo Convert
Ken Horner is offline
post #4 of 17 (permalink) Old 09-15-2009, 06:42 PM
R8D-XXX's Avatar
I've seen chrome fan blades before. But I'm sure it cost a lot more to get done than the wheel are worth unless you just really like them.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #5 of 17 (permalink) Old 09-15-2009, 06:44 PM
especially when, if you are lucky, you can find factory chrome fan blades
poomwah is offline
post #6 of 17 (permalink) Old 09-16-2009, 04:01 AM
Jeremys95Thunderbird's Avatar
I have a set I was able to find, they are in my basement waiting to go on my 95.
1995 LX 4.6 Stock for now.
Jeremys95Thunderbird is offline
post #7 of 17 (permalink) Old 09-16-2009, 04:44 AM Thread Starter
Well F the PITA polishing!!!
I'm gonna go with the paint like in the pic, 'cept maybe try to polish up the lip and see how it turns out.
For some reason I'm not a big fan of big bling rims on these cars..
Thanks!
post #8 of 17 (permalink) Old 09-16-2009, 12:10 PM
ZackG's Avatar
you copy cat!
97 Tbird 4.6
Vortech at XY psi
4.10's, KB boost a spark.
Yummy.
ZackG is offline
post #9 of 17 (permalink) Old 10-05-2009, 12:17 AM
CrystalPistol's Avatar
I agree, lots of work getting them cleaned and polished. Not so bad once done and the surface is smooth. I touch them up occasionally with Hipatchie Semi Chrome or Mothers.
And here are some 10 holes on the '85 I done back in 1997, picture taken in 2008.
CrystalPistol is offline
post #10 of 17 (permalink) Old 10-10-2009, 08:46 AM
Nitemare's Avatar
CrystalPistol, did you paint the insides of the spokes on those 7 spoke wheels? Also what did you do about the center caps?
Needs more stall.
Nitemare is offline
post #11 of 17 (permalink) Old 12-05-2009, 06:07 PM
Any ideas on refinishing '97 stock SPORT wheels? looks like the clear coat is getting ugly on mine........
Pearl97LXSPORT is offline
post #12 of 17 (permalink) Old 12-05-2009, 08:44 PM
Get them sand blasted and powdercoated. Any good powdercoating shop should have the abilities to do this. The place i had mine done at up here was able to paint in all sorts of different colours if you so chose.
- 4.8.15.16.23.42 -
"You never even hear it when it happens, do you?"
Canadian_LX is offline
post #13 of 17 (permalink) Old 12-30-2009, 09:03 PM
Are those seven spokers sable wheels? I did a set like that, I decided mine looked better without the centers
poomwah is offline
post #14 of 17 (permalink) Old 12-30-2009, 09:27 PM
I wonder what it would cost to get them chromed?
Chrome fan blades look good, but chrome sports would look better!
T-Chicken is offline
post #15 of 17 (permalink) Old 02-24-2010, 04:16 PM
Cool paint/polish factory alloys
we do it all the time here, wheels are stripped, polished, painted with epoxy
primer, then base coat/then clear coat just like a fender. wheels need to be sealed with a good "safe for clear coat paint" wax. if the water runs off, it needs
wax, if it beads up like your hood it's okay. will send pictures of my 10 holes
color matched to the car as soon as they are done. been in the wheel business
41 years.
TIRE BARON is offline
post #16 of 17 (permalink) Old 02-24-2010, 04:21 PM
915.0Sport's Avatar
When polishing Aluminum remember to take it to 2000 grit or you are just polishing scratches
91 Sport 5.0 T-Bird
74 Howell EFI Injected Bronco
73 5.0 MAF Bronco Tube Buggy
915.0Sport is offline
post #17 of 17 (permalink) Old 02-24-2010, 04:31 PM
put slicks on them
