Full Size Spare - TCCoA Forums
post #1 of 15 (permalink) Old 10-09-2009, 05:08 AM Thread Starter
Earl's Avatar
Full Size Spare
I have 18x9 bullit's in the front and 18x10 deep dish bullits on the rear...I was thinking about ordering another 18x9 to use for a full size spare if I ever need to.
Right now the car has 275/35/18 tires in the rear and 245/40/18 tires in the front. Say I get another 18x9 like what is on the front for a spare, and put a 245/40/18 on it...if I have to mount it on the rear, will that screw up my limited slip rear end, because of the (possibly) different tire height?
Any suggestions for different tire sizes on my front and rear since I have a 9 adn 10 inch wheel?
Any suggestion for a good tire size for the spare so it won't matter if it's mounted front or rear?
thanx
Earl
Earl is offline
post #2 of 15 (permalink) Old 10-09-2009, 07:08 AM
Rob
Rob's Avatar
Send a message via AIM to Rob
I wouldnt really worry too much about it as long as you only temporarily use it in a "mismatched" position. If you did the same size as the rear tire, you wouldnt have to even think about clutch wear. I'll bet they are close enough that it probably wont matter.
-Rob
-Rob
Rob is offline
post #3 of 15 (permalink) Old 10-09-2009, 09:32 AM
tire calculator only shows 0.1 inch difference in radius. couldn't imagine that would harm much for a temporary drive.
seth
[email protected]=iii=<| is offline
post #4 of 15 (permalink) Old 10-09-2009, 03:35 PM
Overkill Fetish Freak
You can use a Linky LS spare wheel as a MN12 spare if'n you want a bigger then stock spare... spare.
-Scott
Dr. FrankenCougie is offline
post #5 of 15 (permalink) Old 10-09-2009, 07:44 PM
Rob
Rob's Avatar
-Scott
I didnt know those had a full spare stock! Are they 15" steel?
-Rob
-Rob
Rob is offline
post #6 of 15 (permalink) Old 10-09-2009, 11:35 PM Thread Starter
Earl's Avatar
I just found two on ebay one was a 17 inch... the other a 16...still kinda too small...price is high on them too...gonna do an 18x9
Earl is offline
post #7 of 15 (permalink) Old 10-09-2009, 11:39 PM
Why do you need an 18x9 spare? are you doing it for looks or to clear the brakes? Thats alot of dead weight to be adding back there.
post #8 of 15 (permalink) Old 10-10-2009, 03:03 AM
TCCoA Wheel Guru
Earl...If I may ask...Why the need for the fullsize spare?? Just curious
The stock dognut will work fine. Keep the air pressure up and you are good to go. If you do come across a flat (Hope ya dont =) ) If its a leaker keep a portable air compressor in the car and limp to a shop. In most cases this is all ya need unless its a total loss tire issue.
Lastly...When you run those tires out go with a 245-45-18/275-40-18 OR 255-45-18/285-40-18 set. This is the correct size option and will fit the wheel widths better than whats on there. Hit me up if you have any questions.
Enjoy the car. =)
Brad
1990 & 1994 SC's
cudaz101 is offline
post #9 of 15 (permalink) Old 10-10-2009, 10:11 AM
bowez's Avatar
My question is where are you going to put it cause I couldn't get a 215-70-15 in the spare well.
93 SC Tbird
96 1/2 XR7 Sold and Salvaged
93 5.0 Tbird
bowez is offline
post #10 of 15 (permalink) Old 10-10-2009, 09:32 PM
Rob
Rob's Avatar
X2 when I went bullitt wheel crazy, I almost got a spare 17" bullitt 245-45r17 and finally decided against it due to the shallow spare tire well. I like my trunk to look decent, even if it is a little dusty I'm running a lincoln town car aluminum donut. Its 17" i think, possibly 16" and fits like a glove. I also used a modified mark viii spare tire cover because it is much more rigid.
-Rob
-Rob
Rob is offline
post #11 of 15 (permalink) Old 10-10-2009, 11:35 PM Thread Starter
Earl's Avatar
Enjoy the car. =)
Brad
I want to go with a full size spare for the following reasons:
1. to clear the front brakes
2. to avoid the possible rear end clutch wear issues
3. the car i VERY VERY low, and scrapes at times, as is...a spare doughtnut would make that worse, possibly making the car un-driveable
4. also, I don't like donut spares, they just suck, can't go over 45MPH on them, limited distance, just a bad deal.
5. If I can't fix the bad tire right away, at least the "temporary spare" would be something I could run for a while without problems....as for putting it in the spare tire well, yeah it'll be an issue, might screw with the trunk space a little, but it might be worth it.
I thought about just getting roadside assistance and NOT carrying a spare, but that could be an issue...waiting hours and hours for a towtruck to arrive when I could be back on the road in a matter of minutes just quick changing the tire.
a 17 inch lincoln LS spare might just be an option though.
Earl is offline
post #12 of 15 (permalink) Old 10-11-2009, 12:04 AM
bowez's Avatar
-Rob
Ok thought I was just missing something. Several years ago I asked my body guy if he could make the well deeper and he said would be cost prohibitive. (This was on the Cougar which had need major rear end work).
Though I guess you could do it if you complete cut the well out and make one to accept a 225-60-16 (since I don't see a need for anything bigger for a spare) and used a X brace on top.
I totally understand wanting a real spare, running a 1.5" lowering springs, I doubt a donut would get me from work to home, but I have 4 spares in the shed.
A donut should never go on the front, but the only other option I know of is the 195 Tarsus 15" wheels.
93 SC Tbird
93 5.0 Tbird
bowez is offline
post #13 of 15 (permalink) Old 10-11-2009, 07:49 AM
I use a mark vIII spare but have considered a full size spare and having the trunk well extended for it before due to wanting 13" brakes.
post #14 of 15 (permalink) Old 10-11-2009, 12:35 PM
I have a full size 225-60/15 spare; the stock cover sits a bit high, but the sub box, amp plate, first aid kit, and fire extinguisher keep it in place pretty well.
Making everything not rattle when the sub hits is the hard part, lol. Even the tire has to be held solid...
Anyway; if you're looking into my trunk, you probably aren't going to ***** to anyone about it.
post #15 of 15 (permalink) Old 10-11-2009, 06:24 PM
TCCoA Wheel Guru
Right on....Change the tire sizes to one of the recomended match sets and that will help your being too low problem more than you would think.
Good luck on the LS Spare...
Brad
1990 & 1994 SC's
cudaz101 is offline
