Wheel fitment ? - TCCoA Forums
post #1 of 7 (permalink) Old 11-19-2009, 09:59 PM Thread Starter
Wheel fitment ?
Hey guys I am kind of new to TCCOA and had a question about what size tires would fit on my new rims.
I have a 1996 cougar I just lowered the car 1.25" I have 17x8 Offset: +30mm (1.18") and 17x9 Offset: +24mm (0.94") I will also be running 12mm adpaters.
I was thinking about using 275/50/17 and 245/45/17 would I have any rubbing issues or any other problems with this setup?
Cuban is offline
post #2 of 7 (permalink) Old 11-19-2009, 10:27 PM
Those are going to stick out super far with those adapters, those offsets with the right hubs basicly sit flush with the fender as is.
Why are you using adapters and not doing it the right way?
post #3 of 7 (permalink) Old 11-20-2009, 10:25 AM Thread Starter
From what I have seen adapters are frowned upon here I would like to do a full break and hub swap but I cannot afford any more down time with my car nor do I have the money at the moment.
I would like to have a staggered look is there any other options for this look with it not sticking out as much with this setup?
If not how much do you think it would be sticking out on the font and back sides?
Cuban is offline
post #4 of 7 (permalink) Old 11-20-2009, 11:45 AM
coggonobrien's Avatar
if it was me i'd drive as is, hang onto the extra wheels and save for a hub swap
coggonobrien is offline
post #5 of 7 (permalink) Old 11-20-2009, 12:13 PM
fast Ed's Avatar
If you're talking about bolt pattern adapters, they will be a lot more than 12 mm thick ... more likely 25 to 30 mm thick. If you are looking at spacers, you won't need them with the wheel offsets you plan to use.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #6 of 7 (permalink) Old 11-20-2009, 02:41 PM
Quality adapters cost as much as a hub/brake swap.
All stock 1990 Merc Blue Max Cougar 3.8L with Automatic
ben2go is offline
post #7 of 7 (permalink) Old 11-20-2009, 03:42 PM
Traveler's Avatar
I concur
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
