is this offset to much - TCCoA Forums
post #1 of 5 (permalink) Old 12-30-2009, 09:48 PM Thread Starter
i bought som 18x7.5 wheels today. i have to have the center bore enlarged. they are a 51 offset. i could use a spacer but i prefer not to, is this to much offset for direct application.
pimpcat is offline
post #2 of 5 (permalink) Old 01-02-2010, 08:44 AM
R8D-XXX's Avatar
I know for a fact that 18x7.5's with a 40mm is what most people shoot for when running this size rim. A 51mm offset may be a bit too much. You could use them, but you might have to run AT LEAST a 1/4 spacer to avoid hitting the front spindles.
The difference between a 40mm offset wheel and a 51mm offset is right at 7/16".
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #3 of 5 (permalink) Old 01-02-2010, 05:53 PM
on my 97 mark viii i have 19x8.5 with a wheel offset 46 and had to use i beilive a 8mm spacer, the front wheels were hitting the upper control arm just a pinch..just as reference. i think the marks/t-birds/cougers have the same susp config.
sbcaprice305 is offline
post #4 of 5 (permalink) Old 02-15-2010, 08:26 PM
crash00527's Avatar
Send a message via AIM to crash00527
thats way too much. thats a 1in diff.
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #5 of 5 (permalink) Old 02-15-2010, 08:50 PM
driller's Avatar
driller is offline
