Widest tires/wheels? - TCCoA Forums
post #1 of 30 (permalink) Old 01-05-2010, 07:28 PM Thread Starter
Earl's Avatar
OK, so I have 18x9 Bullitts on the front, and 18x10 Deep Dish Bullitts on the rear.
Is a 9 inch WHEEL too wide for the front? If not, What is the wides front tire I can run without rubbing on anything, and what side profile should the wheel have?
Now, same question on the rear, with a ten inch rear wheel, what is the wides tire I can run without rubbing?
thanks
Earl is offline
post #2 of 30 (permalink) Old 01-05-2010, 07:52 PM
danalba's Avatar
i run 18x9 in the front with 245 40 and im almost positive thats just about as wide as you can go. might be able to go a little thicker, 245 50 or 55 but probably no more than that. mine is only lowered 1.5 and with those cut sport springs im not sure how far you can push it. def be safe with 245 40 though in my opinion. as far as the back pretty much as wide as you want. i think the wider the better. i have 275 40 in the rear with 18x9. you can prlly push atleast 285 maybe even 300 or around there with 18x10.
MAC CAI/02 STANG MAF/SCT CHIP TUNED BY LONNIE
EIBACH 1.5 LOWERING SPRINGS- BILSTEIN GAS SHOCKS
90 SUPERCOUPE SIDE SKIRTS/REAR
18x9-FRONT: 245 REAR: 275
PI intake/PI cams
355 trac lok
new tune for swapped parts (93 oct)
no longer the owner.... but its still my child its just released into the world....
danalba is offline
post #3 of 30 (permalink) Old 01-05-2010, 08:45 PM Thread Starter
Earl's Avatar
Yeah I'm mostly concerned with the front...does having cut springs limit how wide I can go? Would I be in better shape if it wasn't quite as low (voigtlands or eibach, H&R springs, etc.)
Earl is offline
post #4 of 30 (permalink) Old 01-05-2010, 09:31 PM
bagged95's Avatar
it really depends on the backspacing your wheels have.
for example, my wheels are 20x8.5 (6.5" backspacing) with 255/30/20's mounted on them and the sidewall of the tire is roughly 1/8" from rubbing on the spindle arm upfront.
bagged95 is offline
post #5 of 30 (permalink) Old 01-05-2010, 10:01 PM
I think 255 is gonna be the widest you can go in front. Not sure of the overall diameter. Out back on my car I have a widened mustang wheel. Originally 17x8 now 17x10 with a 315 35 and it is super close to the sway bar.
But like bagged95 says it depends on your backspace. I think the new backspace on my widened is 7.25. I could space it out a little and maybe fit a bigger tire, but I would need a wider wheel cause 315 is max on the 10" wide wheel.
BLOWN38 is offline
post #6 of 30 (permalink) Old 01-06-2010, 02:20 AM
danalba's Avatar
offset as well. I think the most offset you can have is like 38mm or around there. I know mine are 38 offset and I have 245 40 like I said with 9 inch in the front and it gives me about an 1/8th inch between the UCA and tire.
but like everyone says, just have to be contiuos of everything. tire size, wheel size, offset, backspacing, I don't really think having it at a lower or higher ride hieght wieghs in as much as the rest though someone with more experiance may disagree
PI intake/PI cams
355 trac lok
danalba is offline
post #7 of 30 (permalink) Old 01-06-2010, 07:14 AM
R8D-XXX's Avatar
yes the offset plays a big role in this. My fronts are 18x9 36mm offset and I have 255/45 tires. Backs are 18x10 45mm offset with 285/40's. I still have a decent amount of clearance in the back and could have gone with a wider tire but the 285's look fine to me.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #8 of 30 (permalink) Old 01-07-2010, 06:04 AM
TCCoA Wheel Guru
245-45-18 front & 275-40-18 rears would be a good choice for that car. 255mm+ rubber up front can contribute and even cause bump steer on these cars which can be really annoying if you travel on alot of imperfect roads.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #9 of 30 (permalink) Old 01-08-2010, 04:38 AM Thread Starter
Earl's Avatar
R8D-XXX
That Car Is Stunning!
Earl is offline
post #10 of 30 (permalink) Old 01-09-2010, 10:49 PM
Wheel Brand
R8D-XXX, what brand wheels are you using on your tbird? Im interested on if you used a wheel spacer, changed the hubs, what wheel pattern you used etc. Im running high power output on my tbird and need the widest tire possible for maximum traction. Thanks.
speedbird8807 is offline
post #11 of 30 (permalink) Old 01-10-2010, 11:51 AM
R8D-XXX's Avatar
Originally Posted by Earl View Post
R8D-XXX
Thanks Earl!
Yes, I did the hubswap. They are mustang wheels with the 05+ offsets.....no spacers. The wheels are Godspeed Omega's from www.cruizinconcepts.com Pretty good guys to deal with. There are I think 4 different style Omega's you can choose from. I went with the machined/black style. Here is a direct link to the page that has the Godspeeds. http://www.cruizinconceptswholesale....heels-rims.asp
However, if you are just wanting to get wide wheels on your car, Brad here on the board (custome wheel shop) can get you a wide setup without having to spend the extra $$$ and doing a hub swap.
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #12 of 30 (permalink) Old 01-10-2010, 07:54 PM
Wheels and Tires
Thanks R8D-XXX. Your Tbird does look good with that wheel and tire combo.
post #13 of 30 (permalink) Old 01-10-2010, 11:19 PM
MAMN12 Posse Member
JeffTBird93's Avatar
I'm running an 18x10 in the back with a 275 right now and no issues at all with the fenders rolled. I've got a friend that's gonna get me a few free sets of used wide tires. Gonna try out a 315 or more next chance I get.
~Jeff
*signed off
JeffTBird93 is offline
post #14 of 30 (permalink) Old 01-12-2010, 12:12 PM Thread Starter
Earl's Avatar
out of curiousity, what all does "rolling the fenders" entail? I know it allows wider tires to not rub, but what exactly is done to the car?
Earl is offline
post #15 of 30 (permalink) Old 01-12-2010, 12:16 PM
MAMN12 Posse Member
Basically you take the rear fender lip, and instead of having it point inward horizontally toward the car, you "roll" it, so that it points up. Me, personally (though many would cringe at the thought), I took a 3 lb. sledgehammer until I got what I wanted. There's many ways to do it, but this was by far the easiest.
Eastwood Company used to sell a tool that bolted to your hub that did a much neater job.
~Jeff
*signed off
post #16 of 30 (permalink) Old 01-12-2010, 01:20 PM Thread Starter
Earl's Avatar
interesting, does it give you quite a bit more room to breathe on tire width?
Earl is offline
post #17 of 30 (permalink) Old 01-12-2010, 01:26 PM
Harbor freight has a fender rolling tool out now(though it might still be on backorder) very similar to the eastwood one, only much cheaper.
post #18 of 30 (permalink) Old 01-17-2010, 10:33 AM
MAMN12 Posse Member
Before rolling it, my 275's would rub slightly on the fender lip. After I rolled them, and while I had the car bagged, I had the rear's fully tucked in the fenders, with about a 1/4" gap between the tire and fender.
~Jeff
*signed off
post #19 of 30 (permalink) Old 01-17-2010, 05:40 PM
Gl@re's Avatar
can anyone confirm that i should be ok with 255/50/R17? they're WAY cheaper than 245/50/r17, but i really want the widest tire i can get. I'm pretty sure the rim size is 17 X 9, but i'm not sure about the back spacing. how can i find out what it is?
post #20 of 30 (permalink) Old 01-17-2010, 07:49 PM
driller's Avatar
http://www.rims-n-tires.com/rt_specs.jsp
I have 255/45-18 on 18x9 wheels with 30mm offset (6.2" backspace) - that is as close as you will get on the front.
driller is offline
post #21 of 30 (permalink) Old 01-17-2010, 08:36 PM
Gl@re's Avatar
ok, so i'm gonna have to measure it. thanks.
post #22 of 30 (permalink) Old 02-05-2010, 08:48 AM
Been thinking about a set of 17x9s, just throwing this out there based on what I've read here.
245-45-17s on the front should work, but what about 285-40-17 on the rear? Is that going to be too wide for a 9 inch wheel? They will have a +36mm offset.
post #23 of 30 (permalink) Old 02-05-2010, 08:56 AM
TCCoA Wheel Guru
255-45-17/285-40-17 and yes they will work fine on a 9" wide wheel.
1990 & 1994 SC's
cudaz101 is offline
post #24 of 30 (permalink) Old 02-07-2010, 11:22 AM
crash00527's Avatar
Send a message via AIM to crash00527
im going with 99 ford racing cobra wheels.
17x9 offset +30
245/45/17
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #25 of 30 (permalink) Old 02-07-2010, 03:20 PM
TCCoA Wheel Guru
No...There are pletny of guys running a +36MM offset with a 9" wheel using the 255-45-18 tire option with no probs. Well just a lil rub on the plastic fender skirt/liner at full lock.
+30MM in the front with a 9" wide wheel would not be very desirable with respect to outter tire position regardless of what size it is.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #26 of 30 (permalink) Old 02-07-2010, 03:23 PM
TCCoA Wheel Guru
17x9 offset +30
245/45/17
Not the best offset for our cars. Will it fit?? Sure...Will it look good?? In my own humble opinion...Not as good as it could look with a lil more posative offset.
245MM rubber will work BUT again its not the best choice. 255-45-17 is a pretty common size and not overpriced with many tire option choices. The 245-50-17 would be perfect but they can be expensive and the tire choices are not that great.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #27 of 30 (permalink) Old 02-07-2010, 11:30 PM
MAMN12 Posse Member
I run an 18x9 in the front with a 30mm offset and I think it gives it an aggressive stance. That's with a 245/45/18.
~Jeff
*signed off
post #28 of 30 (permalink) Old 04-27-2012, 09:01 PM
Sorry for the old thread bump in advance!
I'm going to be in the market for another pair of tires here soon, and with the extra stall I've got I'm thinking I'll get some wider tires for the rear. I can't seem to find anything tall enough for a 17" tire that's any substantial amount wider than what I have (255/45/17) aside from 285/40/17 - exactly the combo Brad mentioned.
Now - my question is if fender rolling is required for something this wide with a non-lowered vehicle without air bags. Also if anyone has any pictures of this in a +36mm 9" wheel, that would be great.
post #29 of 30 (permalink) Old 04-27-2012, 09:21 PM
Mine are 275/40/18 Street, 285/40/18 Strip in the rear. 36mm offset on 18x9" rims.
Sorry they're 18's but you get the idea ...
There are others here who run the 17's that don't look a bit different than mine. check out the Wheel Pix thread for lots of examples.
I get some rub in the back but I have a VERY firm suspension that keeps that to a minimum. So, in a nut shell, no. Fender rolling isn't "required" especially on a non-lowered vehicle.
I do plan to get my fenders rolled later this summer when I send the car in for paint.
See my gallery and this post for lotsa pix.
http://forums.tccoa.com/showpost.php...&postcount=269
post #30 of 30 (permalink) Old 04-27-2012, 09:42 PM
Awesome Ron. Very informative as usual.
I won't be replacing the tires until later this year at best - the tires that are on there have a little bit left to them that still needs to be roasted off.
