wheel hubs ? - TCCoA Forums
post #1 of 61 (permalink) Old 02-03-2010, 12:14 PM Thread Starter
wheel hubs ?
Why can't you buy new wheel hubs, press the studs out, and redrill for a 4.250 bolt pattern?
profalconn is offline
post #2 of 61 (permalink) Old 02-03-2010, 12:21 PM
hugh?
you can buy new hubs with the correct bolt pattern...
http://www.oreillyauto.com/site/c/de...3338&ppt=C0062
post #3 of 61 (permalink) Old 02-03-2010, 12:28 PM
R8D-XXX's Avatar
hugh?
Yeah I don't get it either.
OP, are you talking about fronts or backs? If you are talking about fronts, you can buy new t-bird hubs with the 4.25" bolt pattern or you can buy SN95 mustang front hubs and they are a direct swap.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #4 of 61 (permalink) Old 02-03-2010, 01:45 PM Thread Starter
hubs
I'm new to this forum so forgive me. I 'm also a machinist so I look at things in a different way. Thanks for the responce.
JC
post #5 of 61 (permalink) Old 02-03-2010, 01:46 PM Thread Starter
sorry
I meant drill them for a standard 4.5 BC.
post #6 of 61 (permalink) Old 02-03-2010, 02:32 PM
coggonobrien's Avatar
for that you use sn-95 mustang front hubs and 99 cobra rear hubs, no need to machine
coggonobrien is offline
post #7 of 61 (permalink) Old 02-03-2010, 02:47 PM Thread Starter
hubs
No need for any other parts? Bearings, everything is the same?
post #8 of 61 (permalink) Old 02-03-2010, 03:05 PM
For us, the hub and bearing are sold as one piece.
post #9 of 61 (permalink) Old 02-03-2010, 04:21 PM Thread Starter
hubs
Great, I already have 95 hubs for my fox body 4 banger. The Cobra hubs I would need would be the same year range?
post #10 of 61 (permalink) Old 02-03-2010, 04:31 PM
Cobra hubs need to be from a 99-04
post #11 of 61 (permalink) Old 02-03-2010, 06:25 PM
R8D-XXX's Avatar
http://members.tccoa.com/dlf/Article.html
Here, all you need to know.
pics of my car
Updated 10/14/11
R8D-XXX is offline
post #12 of 61 (permalink) Old 02-03-2010, 08:17 PM
Correct me if I'm wrong, but isn't ANY 1994-2004 Mustang an SN-95? I know the Mustang had some pretty substantial changes for 1999, but it was still basically the same car.
post #13 of 61 (permalink) Old 02-03-2010, 09:05 PM
DLF
DLF's Avatar
'94-'04 for the front hubs.
'99-'04 Cobra w/IRS for the rear hubs.
My Web Site
DLF is offline
post #14 of 61 (permalink) Old 02-10-2010, 08:10 PM
crash00527's Avatar
Send a message via AIM to crash00527
thats what i though you meant. i was just gonna correct you lol
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
post #15 of 61 (permalink) Old 02-10-2010, 08:17 PM
crash00527's Avatar
Arrow
on another note.. lol i kinda have have the same dilemma....
I have a 95 SC --- bolt pattern 5x4.25 offset +39 .
I just bought my FAVORITE 99 5 spoke cobra wheels. Part #F9ZZ-100-7EA
bolt pattern 5x4.50 offset +26 I think
we can do the hub swap...... fine.. i guess. but don't we also have to get new rotors, brakes, calipers to accommodate the different bolt pattern?? i dont have the time or money set aside for those items... you being a machinist, can I just press out the studs like you said and re-drill the holes or re-drill the wheel holes instead
OR can this work temporarily?......
http://cgi.ebay.com/ebaymotors/RIM-W...ht_4646wt_2210
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #16 of 61 (permalink) Old 02-10-2010, 08:44 PM
Adapters are dangerous junk. Redrilling the wheels is just as bad.
You can reuse your calipers and use cheap mustang rotors on the front. The rear you can either redrill the stock rotor using the stock caliper or use mustang calipers and rotors.
post #17 of 61 (permalink) Old 02-10-2010, 08:49 PM
crash00527's Avatar
now.... when i do, do the full hub swap, the proper way. what year mustang parts should i use?
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #18 of 61 (permalink) Old 02-10-2010, 08:51 PM
post #19 of 61 (permalink) Old 02-10-2010, 08:52 PM
crash00527's Avatar
lol ..that bad huh....how bad can it be to re-drill 1/8 in though?
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #20 of 61 (permalink) Old 02-10-2010, 08:53 PM
crash00527's Avatar
duh...
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #21 of 61 (permalink) Old 02-13-2010, 07:00 PM
crash00527's Avatar
last stupid question i forgot to ask before...
why cant i re-drill the front rotors along with the rear?
is it hard to that?
if i have an offset of +26 or so on my new wheels, how much do you guesstimate they will be sticking out?
thanks guys much appreciated
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #22 of 61 (permalink) Old 02-13-2010, 09:07 PM
tbirdtess's Avatar
Rears
Hello
Well the parts up front are cheaper as Mustang parts than T-bird parts.
Bolt right on, 93up.
Rears
You can get your hubs redrilled, there is a Cobra guy that does it fairly inexpensive.
Or you can purchase Mustang Cobra rear hubs.
You will have to redrill the rear rotors or drums either way.
Mustang rear rotors have a different offset.
I am 1/2 way threw the swap. Working on the rear bushings right now.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #23 of 61 (permalink) Old 02-13-2010, 09:45 PM
is it hard to that?
You can redrill both, but the mustang hub center is a larger diameter. It will require more precice machine work on all 4 rotors vs. just the rears.
Besides, mustang front rotors are cheaper than dirt
They'll be sticking out alot with craptacular adapters. My wheels are +26mm 17x9s and they sit out slightly as is.
post #24 of 61 (permalink) Old 02-14-2010, 08:50 AM
crash00527's Avatar
Rear cobra rotors have a different offset? How so and by how much?
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #25 of 61 (permalink) Old 02-14-2010, 08:53 AM
DLF
DLF's Avatar
Have you read THIS?
My Web Site
DLF is offline
post #26 of 61 (permalink) Old 02-14-2010, 08:54 AM
crash00527's Avatar
I think I'm just gonna shell out the money for the cobra rotors... I really don't wanna buy new calipers. Do I have too? Are the regular mustand or gt rotors more compatible to our stock sc. I think redrilling now is gonna throw the tension rating off on the hubs and rotors now that you mention it... No?
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #27 of 61 (permalink) Old 02-14-2010, 09:31 AM
crash00527's Avatar
Originally Posted by DLF View Post
Have you read THIS?
yea i just printed it out. thanks!
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #28 of 61 (permalink) Old 02-14-2010, 11:58 AM
tbirdtess's Avatar
Fit
Hi
My problem is that I need to fit under 15" steel racing wheels.
351W 2bbl.
C-4 Auto
3.90 open rear
post #29 of 61 (permalink) Old 02-14-2010, 12:01 PM
crash00527's Avatar
gotchya.. lol
1 of 5,167
SCCOA Member #3093
CPL/0861/0844 USMC
post #30 of 61 (permalink) Old 02-14-2010, 12:12 PM
DLF
DLF's Avatar
Originally Posted by tbirdtess View Post
Hi
That's probably not going to happen.....
My Web Site
DLF is offline
