Bolt pattern does it fit - TCCoA Forums
post #1 of 2 (permalink) Old 02-08-2010, 02:53 PM Thread Starter
pnyklr's Avatar
Send a message via AIM to pnyklr Send a message via Yahoo to pnyklr
My XType has 5-108 bolt pattern just like the SC
I looked up rims for both the tbird and x type and found this
SC +42mm offset, backspacing 5.90 bolt pattern 5-108
Xtype +45mm offset. backspacing 6.02 bolt pattern 5-108
these were just two rims I picked at random from tirerack
I wonder if the tbird rims would fit
Basically the concept is I want to get my rims repaired and if these worked it would be awesome
Chris
87 GN,94 Prizm,05 Suburban Z71
pnyklr is offline
post #2 of 2 (permalink) Old 02-08-2010, 05:12 PM
crash00527's Avatar
Send a message via AIM to crash00527
yes the will be fine chris.
lower the offset # more they stick out. higher the offset # more in the wheel well they go.
backspace shouldn't be to far off. bolt pattern should be the same. unless you wanna re-drill the holes larger or doa hub swap..which becomes pretty pricey
1995 40th. Ann. Supercoupe
1 of 5,167
Black ~ AOD ~ Moonroof ~ 82K
SCCOA Member #3093
CPL/0861/0844 USMC
Forward Observer/Fire Direction Center
Click below for Current PICS and MODS.
http://www.cardomain.com/ride/2466286
crash00527 is offline
