what is the largest tire for 17'' Cobra rims on a 97 Cougar? - TCCoA Forums
post #1 of 13 (permalink) Old 02-15-2010, 06:22 PM Thread Starter
RCReevesPhotography's Avatar
Hello,
Before I sold my 97 Cougar I put on a set of 17'' Ford Racing Cobras on it.
The new owner would like to know what is the largest tire that can be used with out a rub?
If I recall it has 255/45/17 now.
"Dream like you will live forever, live like you will die today"
RCReevesPhotography is offline
post #2 of 13 (permalink) Old 02-15-2010, 06:24 PM
Gl@re's Avatar
it depends on the offset. 255/45/17 can rub on some, 245/50/17 is usually safe.
post #3 of 13 (permalink) Old 02-15-2010, 06:37 PM Thread Starter
If I recall they are the factory 97-98 style
5.72" backspacing
30mm offset
So 55/17 would be a bad idea?
post #4 of 13 (permalink) Old 02-15-2010, 06:40 PM
Gl@re's Avatar
i'm not 100% sure, but that's what i've heard here.
post #5 of 13 (permalink) Old 02-15-2010, 06:44 PM
I've read that 255/45 is about all you'll get, at least on the fronts. If I ever get my hands on the wheels I want I'll probably go that size up front with 285s in the rear.
post #6 of 13 (permalink) Old 02-15-2010, 06:46 PM Thread Starter
I have a set of three 235/55/17's I'm about to remove from my crown vic and he wanted to use them if they would fit.
I'm just unclear about the 55 I think it will be to tall and rub.
post #7 of 13 (permalink) Old 02-15-2010, 06:51 PM
Gl@re's Avatar
well, i don't think it'll rub, but it'l make his spedo about 2% off
http://www.miata.net/garage/tirecalc.html
post #8 of 13 (permalink) Old 02-15-2010, 06:51 PM
235/55 is 27.2" in diameter, stock 205/70 is 26.3" in diameter. 255/45 is 26.0" in diameter (and 285/40 is 26.0" as well fwiw).
post #9 of 13 (permalink) Old 02-15-2010, 06:55 PM Thread Starter
I think they are going to look goofy since they are not as wide. But I kind of like my tires wide.
post #10 of 13 (permalink) Old 02-15-2010, 06:56 PM Thread Starter
So I guess the question is does the car have an extra 0.9?'' lol
I hope that math is right, I never was good at math lol..
post #11 of 13 (permalink) Old 02-15-2010, 06:58 PM
Don't forget, that's diameter. You'll actually be 0.9" taller overall, however only 0.45" of that will be over the height of the stock size but on both sides.
post #12 of 13 (permalink) Old 02-15-2010, 06:59 PM Thread Starter
I could see it clearing in the back but I don't think it will clear the control arm's in the front.
post #13 of 13 (permalink) Old 02-15-2010, 07:08 PM
I honestly don't think an extra half inch is going to make that big a difference in clearances unless you're ridiculously lowered. The biggest thing I'd worry about is the speedo; with a 235/55 you'd be 3% off, more or less meaning that at 60MPH your speedo says you're going 58.
