20x8.5 40mm wheel/tire ? - TCCoA Forums
post #1 of 20 (permalink) Old 02-25-2010, 01:05 PM Thread Starter
MRCYCOUG's Avatar
Who running 20x8.5 40mm wheels, what tires are ya running
________
Ferrari 159 S picture
MRCYCOUG is offline
post #2 of 20 (permalink) Old 02-25-2010, 03:53 PM
Wink 20" Tire Sizing
I Would Try 245/35r20 - It Is 26.8" Tall V/s 26.6 On The Stock 225/60r16
I Personally Would Not Go Any Larger Than 18" Without Upgrading The
Brakes As You Are Hanging Some Pretty Good Weight On The Spindles
Lots Of Guys Do It, But They Care More About Bling Than Performance.
Tire Joe
TIRE BARON is offline
post #3 of 20 (permalink) Old 02-25-2010, 04:57 PM Thread Starter
MRCYCOUG's Avatar
I know bout the more rotation to stop with bigger rims, that will be later after I get a spare if I do go with bigger brake disk or just maybe more piston calibers, thanks for the info how bout a bit wider tire in back
________
magic flight launch box review
MRCYCOUG is offline
post #4 of 20 (permalink) Old 02-25-2010, 06:37 PM
as reference im running 19x8.5 with a 46 offset. had to use a 8mm spacer though. tires are 235/45/19....
sbcaprice305 is offline
post #5 of 20 (permalink) Old 02-25-2010, 07:18 PM
TCCoA Wheel Guru
If you want a wider rear then you will have to match up a rear wheel with a 9-10" width. Going with 8.5" all the way around pretty much locks in 245MM rubber all the way around, if you do it right. There are advantages to this that increase tire life enabling you to rotate your tires.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #6 of 20 (permalink) Old 02-25-2010, 07:30 PM Thread Starter
MRCYCOUG's Avatar
So it possible to go with a 55 in the rear, I was bout to go with the billet but then found some y2k but then found a deal on some enkei kapones that I could pass up, I've wanted a wide rear. But mite have to get another set of rims
________
CleanEnergy
MRCYCOUG is offline
post #7 of 20 (permalink) Old 02-25-2010, 07:44 PM
TCCoA Wheel Guru
255-35-20 is 27" tall...You would exp. a lil rub in the front on the inner plastic fender skirt.
IMO the appearance of the 245-35-20 will look more correct and clean in comparison.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #8 of 20 (permalink) Old 02-25-2010, 07:55 PM Thread Starter
MRCYCOUG's Avatar
But the rear will be good for. 55or bigger, I just want the rear to be wider
________
O405
MRCYCOUG is offline
post #9 of 20 (permalink) Old 03-29-2010, 03:35 PM Thread Starter
MRCYCOUG's Avatar
my mark viii with enkei kapones 20x8.5 40mm offset......
http://www.flickr.com/photos/[email protected]/4474508766/
________
Yamaha TT250
MRCYCOUG is offline
post #10 of 20 (permalink) Old 04-03-2010, 03:01 PM
bagged95's Avatar
im running 255/30/20s on all 4 corners
bagged95 is offline
post #11 of 20 (permalink) Old 04-22-2010, 05:24 AM Thread Starter
MRCYCOUG's Avatar
I would hate to run such a small profile tire. I like thinkness ( more so in woman )
________
buy vapolution
MRCYCOUG is offline
post #12 of 20 (permalink) Old 04-24-2010, 01:05 PM
bagged95's Avatar
Hate it all you want, then hate some more.
bagged95 is offline
post #13 of 20 (permalink) Old 04-24-2010, 06:43 PM Thread Starter
MRCYCOUG's Avatar
Think I might sell to get some 18's instead
________
Mercedes-Benz W128
MRCYCOUG is offline
post #14 of 20 (permalink) Old 04-25-2010, 09:31 PM
bagged95's Avatar
ive got a set in the "parts for sale" section. check them out
bagged95 is offline
post #15 of 20 (permalink) Old 04-26-2010, 11:12 AM
mybird_91's Avatar
Send a message via Yahoo to mybird_91
agreed..... i'm not a dog, i want some meat on them bones. lol
900th post!!!
1994 Chevrolet Camaro Z28
LT1 350
K&N Intake and Flowmaster Exhaust
1995 Lincoln Mark VIII
hollow front cats, 3rd cat still there, no resonator, replaced by a single 40 series flowmaster, 2 3"x18" tips out back. screamin demon coil packs, mallory pro wires, motorcraft platinum plugs. intake resonator delete.
mybird_91 is offline
post #16 of 20 (permalink) Old 04-26-2010, 08:19 PM Thread Starter
MRCYCOUG's Avatar
900th post!!!
900 dam I haven't even hit 500 and I been a member since 2002.
________
BMW Sauber F1.06 specifications
MRCYCOUG is offline
post #17 of 20 (permalink) Old 06-06-2010, 03:33 PM
90 sc 460's Avatar
265-35-20 or 275-35-20
90 sc 460 is offline
post #18 of 20 (permalink) Old 06-09-2010, 04:53 PM Thread Starter
MRCYCOUG's Avatar
I'm close to rubbing with 245-35
________
Toyota V engine
MRCYCOUG is offline
post #19 of 20 (permalink) Old 06-18-2010, 12:21 AM
90 sc 460's Avatar
255-35-20 front and 275-35-20 rear
post #20 of 20 (permalink) Old 06-18-2010, 11:11 PM Thread Starter
MRCYCOUG's Avatar
What brand tire. What your offset on the rims.
________
medical marijuana states
MRCYCOUG is offline
