lug nuts.. - TCCoA Forums
post #1 of 9 (permalink) Old 03-11-2010, 09:26 PM Thread Starter
TwoHaggard's Avatar
lug nuts..
this may be a silly question. but i wanna get black lug nuts since they would go better with my black cobras. but i just dont kno what size to get? what size are they? when u go to summit theres a lot to chose from. any input would be great.
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 9 (permalink) Old 03-11-2010, 10:19 PM
http://forums.tccoa.com/showthread.php?t=127633
17 posts underneath yours...
post #3 of 9 (permalink) Old 03-12-2010, 01:46 PM
Wink black lug nuts
gorilla automotive makes black lug nuts. check with them online to find your closest vendor
when installing, put a sandwich bag over the lug, and then slide a six point socket over the top to protect the finish
Last edited by Sir William; 03-12-2010 at 02:20 PM. Reason: Removed advertising/selling language.
TIRE BARON is offline
post #4 of 9 (permalink) Old 03-12-2010, 09:51 PM Thread Starter
TwoHaggard's Avatar
ok cool thanks, question tho. would these work? http://www.summitracing.com/parts/SUM-754001B/
post #5 of 9 (permalink) Old 03-13-2010, 12:48 PM
lug nuts
those will work fine, make sure to run down by hand, then hand torque with
a baggie over the nut to prevent finish from coming off-tire baron
post #6 of 9 (permalink) Old 03-13-2010, 03:50 PM Thread Starter
TwoHaggard's Avatar
ok cool. i was just a little bit iffy cuz they were the closed end kind.
post #7 of 9 (permalink) Old 03-13-2010, 11:31 PM
Black_Cat's Avatar
Would those work with cobra's from the custom wheel shop
2011 BMW X5 35i Premium Package
2009 BMW 535i ///M Sport Package
Black_Cat is offline
post #8 of 9 (permalink) Old 03-15-2010, 06:27 PM
lug nuts
yes they will work with brad's wheels, he can get them for you - cardinal rule:
never, never put heavy lubricant on wheel studs with closed end nuts...clean
and dry threads only otherwise torque will be altered - tire baron
post #9 of 9 (permalink) Old 03-15-2010, 07:06 PM
Bradone's Avatar
Thank You! I will throw one in the glove compartment!
Brad
[email protected] (engine/trans is stock)
Bradone is offline
