what air pressure for 225s? - TCCoA Forums
post #1 of 10 (permalink) Old 04-21-2010, 07:06 AM Thread Starter
GRNDPNDR's Avatar
The door panel label on the car states 30PSI for 205s(I think that's what it says) but my car has 225/75/16 (Again, going from memory, gonna check when I leave this morning) and they were pumped up to 44PSI.
I wondered why my ride was so hard..... so I let air out and they are now at 40PSI but I want the fill them to the correct pressure and I'm not sure what it should be for this size tire.
for some reason the pressure rating is not on the sidewall of the tire, so does anyone know what the correct pressure should be?
Rest In Peace Mom.
GRNDPNDR is offline
post #2 of 10 (permalink) Old 04-21-2010, 07:17 AM
The pressure rating on the side of the tire is the max pressure and load the tire will handle, NOT necessarily what the pressure should be set to.
I would put them at 32 psi and play around from there to get the most durability and handling possible. Tire pressures can really impact how a car drives.
69 F100 LWB w/460 Engine
post #3 of 10 (permalink) Old 04-21-2010, 07:19 AM Thread Starter
GRNDPNDR's Avatar
I know, that's why I wanted to get the correct pressure, I don't know who filled them up, but I never checked them all winter until yesterday.
and I'll tell ya, after I let the air, even only 4PSI, it made a difference in drive-ability right away.
Rest In Peace Mom.
GRNDPNDR is offline
post #4 of 10 (permalink) Old 04-21-2010, 08:58 AM
Icarus's Avatar
+1
Also, you need to check them more than once a season too
Ϣr
1994 Lincoln Mark VIII
4.6L DOHC; meter4it.com chase/sequential tail lights; 20" Giovanna Dalars; 4.30 gears; FRPP Track-Lok; SCT tuned; Baumann ReCal; Addco bars; Cobra brakes...
RIP - '86 Mark VII LSC
Icarus is offline
post #5 of 10 (permalink) Old 04-21-2010, 11:17 AM Thread Starter
GRNDPNDR's Avatar
Originally Posted by Icarus View Post
+1
I know..... I'm a terrible person, I should be tarred and feathered.
I'll let some more air out of them today and see how it fares.
Rest In Peace Mom.
GRNDPNDR is offline
post #6 of 10 (permalink) Old 04-21-2010, 04:02 PM
tbirdtess's Avatar
Oval??
Hello
For my Oval car.
LF 15
RF 32
LR 18
RR 28
That's for the 225's we used to run.
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #7 of 10 (permalink) Old 04-21-2010, 05:55 PM Thread Starter
GRNDPNDR's Avatar
I'm not doing any oval track racing..... or any at all for that matter. I think that pressure combo would be a little weird on a DD.
Rest In Peace Mom.
GRNDPNDR is offline
post #8 of 10 (permalink) Old 04-24-2010, 08:58 AM
bgck7's Avatar
tire pressure
I would run 32-34 psi all around for daily driving, if your racing someone i would recommend 38-40 psi, you have to remember, once you start driving a while the tire will heat up and expand, so check them before driving and never when the tires are hot.
regards,
ramon
bgck7 is offline
post #9 of 10 (permalink) Old 04-24-2010, 09:30 AM
ortbird's Avatar
I run fronts at 34 PSI and rears at 32 PSI
(this is with 235/60/16 though, on oem sport wheels)
ortbird is offline
post #10 of 10 (permalink) Old 03-18-2011, 11:26 AM
I've got mine set for 34 PSI all around on OEM rims and tire size is 225/70/15. Max tire pressure on side wall indicates 44 PSI.
Sleeper_95 is offline
