295/50R15 tire on 7 inch rim - TCCoA Forums
post #1 of 16 (permalink) Old 05-14-2010, 10:19 PM Thread Starter
Curtscat's Avatar
I would like to put wider tires on the back of my Cat. The 295/50's are the same diameter as the stock tires, but are 3 inches wider.
Would there be any problem putting that wide of a tire on a 7 inch wheel?
Thanks.
Curt
"I am the way, the truth, and the life. No one comes to the Father except through Me." Jesus
Curtscat is offline
post #2 of 16 (permalink) Old 05-14-2010, 11:21 PM
I don't think something that wide would fit. Recommended minimum rim width for tires that size is 8".
Widest I'd ever go personally on a 7" rim is 255. Even then there will be an awful sidewall bulge. Heck, I'm running 255s on my 9" rims.
post #3 of 16 (permalink) Old 05-14-2010, 11:46 PM
Buckcreekbilly's Avatar
I have 255/60 15 on the back of my bird with stock fanblades, they don't bulge at all but i agree that would be about the max.
95 Thunderbird LX 4.6
K&N cold air intake. True 2 1/4" duals, Xenon GFX. 3:55 Trac loc. Beefier trans, 2800 stall convertor, MkV111 aluminum driveshaft.
Buckcreekbilly is offline
post #4 of 16 (permalink) Old 05-17-2010, 09:40 AM
fast Ed's Avatar
295/50/15 should be on at least an 8" wheel, even that will bulge a bit. 10" is the best size for that, you're looking at an 11-1/2" wide tire.
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #5 of 16 (permalink) Old 07-09-2010, 09:40 AM
Send a message via AIM to Stocker
Proof that they'll fit, but I wouldn't recommend it (at least referring to 7" rim, not on the car):
1991 LX Thunderchicken
4 wheels/tires, A motor/ transmission, few seats and gauges
Yep, she's got it all
Stocker is offline
post #6 of 16 (permalink) Old 07-09-2010, 05:57 PM
coggonobrien's Avatar
275/60 r15 worked just fine for years on my rear fan blades
coggonobrien is offline
post #7 of 16 (permalink) Old 07-09-2010, 07:36 PM
conversion02's Avatar
If you want to put a 295 on a 7" wide rim, you better not plan on taking any corners at any decent speed...
holy sidewall flex batman!
conversion02 is offline
post #8 of 16 (permalink) Old 07-09-2010, 07:37 PM
No bulge with 255's on stock fanblades? I'd have to see it to believe it.
post #9 of 16 (permalink) Old 07-12-2010, 12:55 AM
moore89's Avatar
Years back, I mounted a worn out pair on my 95's fanblades out of boredom. They will physically mount on the wheels but I'd never drive on them like that. If I remember correctly, they looked like they would rub the fender a bit if it hit a bump too.
1990 35th Anny. Supercoupe (under construction). 1991 Supercoupe (tastefully modded). 1989 5-speed Supercoupe (modded). 2003 Yamaha YZF600R (rocket)
1989 Taurus SHO (very lightly modded, but broken again)
1967 Ford F100 2WD (460 bored .060 over, too much cam and gearing for the street).
moore89 is offline
post #10 of 16 (permalink) Old 07-12-2010, 10:23 AM
Mark M. TCCoA VP's Avatar
245-50-15s are about it but depending on the tire (Brand Design) go with 255s but that is the MAX MAX limit IMHO. I ran 245-50s for years on the stock rims and they are more like 6.5s than 7s
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #11 of 16 (permalink) Old 07-12-2010, 11:48 AM
here's 275/60 r15's on stock fan blades. like i said ran them for three years as my daily driver with no issue.
David
post #12 of 16 (permalink) Old 07-12-2010, 12:15 PM
pilgrim's Avatar
[QUOTE=coggonobrien;1316675]here's 275/60 r15's on stock fan blades. like i said ran them for three years as my daily driver with no issue.
Is that the same size in the front?
I'd like to put this size tire on my stock 95 Cougar.
pilgrim is offline
post #13 of 16 (permalink) Old 07-12-2010, 12:28 PM
nope fronts were 235/60 r15, personally i wished i had gone closer to the original diameter on the front, went back to running the stock size when i switched to my weld pro stars
post #14 of 16 (permalink) Old 07-12-2010, 03:16 PM
pilgrim's Avatar
Thanks for the info.
I'm go'n to try this size for the rear tires and close to stock in the front.
Again Thanks!
pilgrim is offline
post #15 of 16 (permalink) Old 07-15-2010, 01:09 AM
275/50x15 on my stock 15in cougar rims with no bulge
mine are nitto drag radials
also i ran 28x9x15 slicks on the stock fanclades with no problems
shoot me a text at
3046166398
and ill take a pic with my cell and send back
mike
1990 ford f150 5.0
1989 cougar xr-7 5spd 5.0 --249hp/[email protected]
1989 mustang gt [email protected]
1984 tbird 5.0 auto
1999 chevy tracker...wtf!!!!!
joker77_2005 is offline
post #16 of 16 (permalink) Old 07-15-2010, 05:58 AM
95xbird's Avatar
I ran 27x10/ 15 hoosiers on my stock fan blades and they bulged like a mofo on one side. Very scary crossing the traps with those.
Its slow, Really.
LS1 KILLER
1995 svo Tbird. R.I.P.
95xbird is offline
