Question on cobra r rims and tires - TCCoA Forums
post #1 of 15 (permalink) Old 06-20-2010, 09:23 PM Thread Starter
Send a message via AIM to CASTRO847
Question Question on cobra r rims and tires
I'm trying to find out if I'm able to run 18" in the rear and 17" in the front if so what tire size would be best?
CASTRO847 is offline
post #2 of 15 (permalink) Old 06-20-2010, 09:25 PM Thread Starter
Does anybody have any pic on how would this look on a tbird?
post #3 of 15 (permalink) Old 06-20-2010, 11:09 PM
Refrigerator Raider Hater
GreenBird's Avatar
Does your car have ABS? If not you can different height front and rear tires. The rear tires will determine how your speedometer and odometer read in relation to stock height.
http://www.miata.net/garage/tirecalc.html
Matt "Looks Like Egon" Davis
96 Alpine Green V8
02 Audi A8L 4.2Q in Black
GreenBird is offline
post #4 of 15 (permalink) Old 06-20-2010, 11:13 PM Thread Starter
My car does have abs is that an issue can it still be done?
post #5 of 15 (permalink) Old 06-21-2010, 01:19 AM
Traveler's Avatar
most folks that want staggered tires try to keep the same height/diameter, but put wider wheel/tires in the back than in the front. As long as the diameter is the same, it won't make any difference as far as the ABS goes
1997 Thunderbird Sport
Low Miles
Wifes Car
destined to remain stock
1997 T-Bird GT 4.6
<<< SOLD >>>
Traveler is offline
post #6 of 15 (permalink) Old 06-21-2010, 09:54 AM
Mark M. TCCoA VP's Avatar
17s all around and 255-50-17 tires look really good IMHO.
"Mark M. TCCoA VP. Emeritus"
To the Batmobile ! ! !
ADDCO MN12 big bar R&D guru
Mark M. TCCoA VP is offline
post #7 of 15 (permalink) Old 06-21-2010, 03:08 PM
13's or Mildly Broken
17x8 in the front, 18x9 rear.
Tires - 245/45/17 front, 255/45/18 rear
I haven't driven the car lately so I honestly don't remember how far off the speedo is. And for as long as I've had the car, I haven't had any issues with the ABS.
-Melon
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #8 of 15 (permalink) Old 07-02-2010, 12:08 AM
moore89's Avatar
Pics are on 1990 35th anny. Supercoupe with front end swap (reciently returned to stock), now on a 1991 Supercoupe. 245/45/17's on 17x9's front and 275/40/18's on 18x10's out back with about a 3" drop all around. I did a gear change and swapped out all the parts to re-calibrate it so I'm not sure how it would have affected the speed-o. I never liked ABS so I swapped it out to conventional, but like they said in earlier posts, as long as the outer diameter of the tire is the same is should work just fine. If you look closely at mine they have roughly the same OD on mine front to rear, just mean a bit taller sidewall on front. but the smaller dia. rim gives it the look of a more aggressive stance.
1990 35th Anny. Supercoupe (under construction). 1991 Supercoupe (tastefully modded). 1989 5-speed Supercoupe (modded). 2003 Yamaha YZF600R (rocket)
1989 Taurus SHO (very lightly modded, but broken again)
1967 Ford F100 2WD (460 bored .060 over, too much cam and gearing for the street).
moore89 is offline
post #9 of 15 (permalink) Old 07-02-2010, 03:58 AM
You can usually get away with about 1 inch difference in tire diameter before it starts causing an abs light.
I like the way those look with 18/17 stagger.
dave281sc is offline
post #10 of 15 (permalink) Old 08-08-2010, 07:33 AM
I have a set of Y2k cobra wheels in chrome, 18s in back and 17s up front . Look at my photo gallery , you will see 2 of my SCs with the wheels on them. I going to sell them if your looking. Im just going back to stock wheels . thanks. DW [email protected]
Ballman is offline
post #11 of 15 (permalink) Old 08-09-2010, 02:55 AM Thread Starter
Why you going back? R u selling or keeping the conversion if so ill buy it of of you and wut its you're suggestion 17 in the back 16 in the front? Or 18 in the back and 17 in the front? Did the 18s rub a lot or wuz it strait? I allso have abs on my 93 5.0 would it work with my abs just wondering before I buy and wut are ur prices 4 the rims ?
post #12 of 15 (permalink) Old 08-09-2010, 02:57 AM Thread Starter
Ohh and are the tires included
post #13 of 15 (permalink) Old 08-09-2010, 03:05 AM Thread Starter
Looks real tuff that's how I want mines to look but I wish I woulnt have to mess with the abs. Did the abs light staid on afta I can't stand watching that light on while I'm driving
post #14 of 15 (permalink) Old 08-09-2010, 03:13 AM Thread Starter
Thumbs up
I don't know man but that looks bad ass verry nice
-Melon
post #15 of 15 (permalink) Old 08-09-2010, 03:25 AM Thread Starter
K I get it I had to read back as long as the diameter is the same It'll not affect my abs sorry bout that :O lol
