Sizes that fit? - TCCoA Forums
post #1 of 9 (permalink) Old 06-30-2010, 11:52 PM Thread Starter
USAF_Bowman's Avatar
Sizes that fit?
What size tires will fit in the back of a 1991 T-bird LX with the 5.0? I'm lookin at a 15x10 for the back. Will those fit or will I need to get spacers... ect?
"Let's take my Thunderbird and leave tonight. I'll keep the pedal to the floor till we see the morning light."
-Reckless by Alabama-
June 13 2010 - Took 2nd in all Ford Car Show in the High School Division
USAF_Bowman is offline
post #2 of 9 (permalink) Old 07-01-2010, 08:29 AM
MAMN12 Posse Member
JeffTBird93's Avatar
I run an 18x10, and I know a few others do. I'm not sure if there would be clearance issues with a smaller diameter.
~Jeff
*signed off
JeffTBird93 is offline
post #3 of 9 (permalink) Old 07-01-2010, 08:38 AM
coggonobrien's Avatar
coggonobrien is offline
post #4 of 9 (permalink) Old 07-01-2010, 08:39 AM
post #5 of 9 (permalink) Old 07-01-2010, 09:18 AM
yeah I think you have to go larger diameter to get the wider wheels. I'm running 18x10 with the only issue being that my E brake cable was rubbing so I had to strap it to the control arm to get it out of the way.
FunktasticLucky is offline
post #6 of 9 (permalink) Old 07-01-2010, 09:57 AM Thread Starter
I found a rim that I really like and think would look great on my T-bird. But I want to put 15x8s up front. But the rears I am debating between putting a 16x9 or putting a 15x10, I defiantly wouldn't mind if they stuck out a little bit though. I think that looks awesome especially on the T-bird since it was still kind of a hold on to the "muscle car"
post #7 of 9 (permalink) Old 07-01-2010, 01:38 PM
r429460's Avatar
If you grind the caliper down enough you dont need a spacer.
If you guys are running them. Then the wheels wont stick out.
Thats a 15 x 8 with 5.5 backspacing.
r429460 is offline
post #8 of 9 (permalink) Old 07-01-2010, 02:15 PM Thread Starter
How far are we talking about having to grind it down, because I am putting the Mustang 2 Pistons in the back. So I'm not so sure if I like the idea of grinding the caliper so much.
post #9 of 9 (permalink) Old 07-01-2010, 09:18 PM
15x8 won't work up front i don't believe, i'm not sure how the mustang calipers will fit, i had to grind a lot on my pbr fronts to fit the welds then slightly on the stock tbird rears to eliminate spacers.
