Unbalanced - TCCoA Forums
post #1 of 21 (permalink) Old 10-04-2010, 09:42 AM Thread Starter
Unbalanced
So I got my tires installed on my new rims about 1 week ago. I asked them to static balance them, put crimp on weights on the inside lip of the rim. Balancing was included with tire purchase.
Well the car shook like mad so a few days later I took it back and was told that the only way to truly balance the rims/tires was to use stick-on weights placed in the center of the rims. Ok fine I'll pay extra. Still shaking alot after 55mph. Took the car back today and let the owner drive the car. He claims its either a ball joint, a UV joint or the U joint, or the disks are warped. I have 8 extra tires for this car and tried them all and the car doesn't shake. The tire shop owner says because these are low profile they will transmit unbalanced things like above.
They don't not use high speed balancing at this shop, so its either the rims are warped, which I'm SCREWED or they just don't know how to balance rims this big.
Opinions please
James
DARKPHREAK is offline
post #2 of 21 (permalink) Old 10-04-2010, 10:02 AM
Find a shop with a hunter road force balancer
post #3 of 21 (permalink) Old 10-04-2010, 10:12 AM
http://www.gsp9700.com/pub/search/findgsp9700.cfm
post #4 of 21 (permalink) Old 10-04-2010, 10:18 AM Thread Starter
Thanks for the info.
So you guys are saying that where I got the tires, they dont know how to balance my tires/rims.
post #5 of 21 (permalink) Old 10-04-2010, 10:44 AM
Any shop will be limited by their equipment.
post #6 of 21 (permalink) Old 10-04-2010, 10:54 AM Thread Starter
Found a local Honda garage that has the Hunter GSP9700, will give them a call for an appointment.
Thanks!
post #7 of 21 (permalink) Old 10-04-2010, 10:55 AM
Exactly it's not that they don't know how it is that they don't have the equipment to handle it. It would be like in my business if someone was building torque converter with a mig welder and a lathe (it does happen) The product will be inferior. I had to go all out or it wasn't worth doing at all.
post #8 of 21 (permalink) Old 10-04-2010, 11:16 AM Thread Starter
Just ticks me off that he said my car was causing the problem when I knew it wasnt and he did say this was the first time they'd seen 18x9's and the valve stems that The Custom Wheel Shop sold me.
post #9 of 21 (permalink) Old 10-04-2010, 11:25 AM
its called not taking responsibilty.
post #10 of 21 (permalink) Old 10-04-2010, 02:03 PM
They have probably never used the expensive balancer to know the difference. On standard wheels their equipment is fine, Don't expect road force balancing to be cheap. The last place I had do it specifically that way charged me $35 per tire. I brought them in the back of my truck.
post #11 of 21 (permalink) Old 10-04-2010, 04:51 PM
A local Mr. Tire that had a GSP-9700 balanced all four of my 17x9 Cobras for $20 after I had another shop mount and balance them on other equipment. It improved the ride quite a bit.
post #12 of 21 (permalink) Old 10-06-2010, 12:06 AM
moore89's Avatar
I Love my 9700 machine, if used properally it balances out so well. It took me two years to talk the higher ups into buying it. When I get my personal shop going, I plan on throwing it in the back of my truck and taking off with it (lol).
1990 35th Anny. Supercoupe (under construction). 1991 Supercoupe (tastefully modded). 1989 5-speed Supercoupe (modded). 2003 Yamaha YZF600R (rocket)
1989 Taurus SHO (very lightly modded, but broken again)
1967 Ford F100 2WD (460 bored .060 over, too much cam and gearing for the street).
moore89 is offline
post #13 of 21 (permalink) Old 10-06-2010, 05:36 AM
TCCoA Wheel Guru
You should not have to go to the extent of a road-force balance service.
The wheels are most deff not warped.
Go to a reputable tire dealer and get them balanced up with a proper Electronic balancer. Yes you have to use tape weights. I cant even imagine static balancing any passenger assembly these days...wow
Make sure the shop pre-torques your wheels and are not just zipping them down without at least a torque stick on the air wrench. Be sure they are using the Hubcentric Ring set as well, these prevent vibration.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #14 of 21 (permalink) Old 10-06-2010, 11:50 AM Thread Starter
Have an appointment with the new Honda in town on Friday. I wonder if the other garage used the hubcentric ring when they balanced the rims, that will affect the balance right?
post #15 of 21 (permalink) Old 10-06-2010, 01:11 PM
The Band, not the Disease!
AnthraxBird's Avatar
Im leaning more towards a bad tire on this one. Try switching the front tires to the rear and see if it helps.
AnthraxBird is offline
post #16 of 21 (permalink) Old 10-06-2010, 04:23 PM
I also love my hunter 9700, since I'm going for my automotive degree and I am taking a steering and suspension course I have access to a hunter gsp9700 road force balancer and 4 different types of hunter alignment machines. My car has never felt so good lol. Finally got all 4 of my Nitto invo 255/50/17's mounted on my bird, using the hunter tcx550. She handles like a dream. I'm a big fan of hunter equipment after using their stuff and their competitions stuff.
post #17 of 21 (permalink) Old 10-06-2010, 08:11 PM Thread Starter
I do notice in the morning that it shakes alot! Cold tires maybe are showing a bad tire.
post #18 of 21 (permalink) Old 10-07-2010, 08:52 PM
I'm almost positive it's a bad tire. Take it back to the shop and have them replace it per the manufacturers warranty.
post #19 of 21 (permalink) Old 10-08-2010, 06:42 AM Thread Starter
Will see what the 9700 turns up. I think it could be the front right thats bad, if so I'll be going back for a replacement. I'll report back when all is said and done.
post #20 of 21 (permalink) Old 10-08-2010, 12:25 PM Thread Starter
Completely balanced, no shakes at all. 55$
Thanks for helping me get to the right shop with the right equipment!
The last shop completly screwed up and had so many weights on the rims everywhere Im not sure what they did.
post #21 of 21 (permalink) Old 10-08-2010, 06:54 PM
TCCoA Wheel Guru
Glad to hear you are all sorted out now. Enjoy the new look!!
Brad
1990 & 1994 SC's
cudaz101 is offline
