bolt pattern swap really worth it?? - TCCoA Forums
post #1 of 27 (permalink) Old 12-01-2010, 11:08 AM Thread Starter
fenix's Avatar
Ok sorry if is dumb question most of my life I been around chevy guys (granpa,dad) so this is my first ford I love the Thunderbird lines (89-97) so I'm tryng to restore mine and make some upgrades and I see some people around make the mustang wheel conversion I read some treads and is not too hard to do it but the main question is if really worth it do the converssion and what's the advantage and thanks for the help
fenix is offline
post #2 of 27 (permalink) Old 12-01-2010, 11:29 AM
13's or Mildly Broken
2 big advantages of doing the hub swap to Mustang pattern - a large wheel selection and easier brake upgrade.
There aren't that many wheel options available for MN12's - especially compared to Mustangs - but there are still good. Check out www.thecustomwheelshop.com for a good selection that are a direct bolt-on.
Brake upgrade can be done, just search "Cobra brake swap" and should be able to find the details.
1999 Crown Victoria P71 4.6
2000 Explorer 5.0
Melon is offline
post #3 of 27 (permalink) Old 12-01-2010, 11:48 AM
Banned
91bluecoupe's Avatar
I am in the process now. Kinda of a pain but will be worth it.
I bought a used set of 98 Cobra rims for $175 bucks cannot beat that.
91bluecoupe is offline
post #4 of 27 (permalink) Old 12-01-2010, 12:02 PM
cobra R Thunderbird's Avatar
X3 on above advises
2001 GT BULLITT #00762 stock
post #5 of 27 (permalink) Old 12-01-2010, 12:15 PM
conversion02's Avatar
x4 - I've got cobra hubs/rims/brakes and I would do it on any other bird from now on. Can't be much harder than the rear disc conversion and the sport/M8 swap on the front that I did on my 94.
Plus, parts aren't THAT expensive on all accounts.
conversion02 is offline
post #6 of 27 (permalink) Old 12-01-2010, 12:18 PM
It's hard to find good wheels in our bolt pattern, but they're out there. I only had to search for three months before I found my wheels, then I had to jump through hoops for another month to actually get them.
After what I went through, I'd just do the swap if I could do it over again. You won't regret it.
post #7 of 27 (permalink) Old 12-01-2010, 12:49 PM Thread Starter
fenix's Avatar
Yes because I like the bullit style and they sell a set from a 06 at $175 a nice lady. She say they were from her boyfriend lol.
fenix is offline
post #8 of 27 (permalink) Old 12-01-2010, 12:51 PM
careful, I think the offset looks funny with those year wheels...
post #9 of 27 (permalink) Old 12-01-2010, 12:53 PM Thread Starter
fenix's Avatar
Really what's the problem with them?
fenix is offline
post #10 of 27 (permalink) Old 12-01-2010, 12:54 PM
I believe they stick out to far.....Big Mike was trying a set from an 05 I believe, and he said the offset just was not right......I'll see if I can find the thread.
post #11 of 27 (permalink) Old 12-01-2010, 12:59 PM
I can take a better pic when I get home, but I don't think mine stick out much...
post #12 of 27 (permalink) Old 12-01-2010, 01:01 PM
I may be completly wrong on this...if so, sorry....
http://forums.tccoa.com/showthread.php?t=110630
post #13 of 27 (permalink) Old 12-01-2010, 01:07 PM Thread Starter
fenix's Avatar
Yes are the same as the conversion02 photo gallery they look great are they 05 06??
fenix is offline
post #14 of 27 (permalink) Old 12-01-2010, 01:27 PM
Are you asking if those are 05-06 Bullitts? Aren't all 05-10 17x8 Bullitts of the same (i.e. these)
I believe these are the rims I have - CLICKY
BTW - the problem with the rims sticking out too far after a hubswap is when you're putting on 9 or 10 inch rims, especially those that are deep dish. Deep dish look great, but you won't want to go with a 10 inch rim unless you like how they stick out. Mine stick out a little and they're only 8 inch wide.
Here's mine, taken with my phone (sorry about the quality).
post #15 of 27 (permalink) Old 12-01-2010, 02:10 PM
17x9 +26mm offset, these just barely stick out...
Hub swap was my first Big mod
post #16 of 27 (permalink) Old 12-01-2010, 02:12 PM
that looks good.....
post #17 of 27 (permalink) Old 12-01-2010, 02:47 PM Thread Starter
fenix's Avatar
Yes they are. Same specs but I can mount different size of tires? Yours are kind tall What. You recommended
fenix is offline
post #18 of 27 (permalink) Old 12-01-2010, 03:02 PM
I'm running 255/50/17 BFG KDWS tires on 17x8 Bullitts. You could put any size tire you want on an 8 inch rim, within reason. I probably wouldn't go much bigger than a 255. I've seen 275s on an 8 inch rim. I personally though it looked like crap, but that's my opinion. There's a couple threads on this topic.
They're not much taller at all. 1/10th of an inch taller to be exact.
http://www.miata.net/garage/tirecalc.html
Tire Size Comparison
Specification Sidewall Radius Diameter Circumference Revs/Mile Difference
215/70-15 5.9in 13.4in 26.9in 84.4in 751 0.0%
255/50-17 5.0in 13.5in 27.0in 84.9in 746 0.7%
post #19 of 27 (permalink) Old 12-01-2010, 04:03 PM Thread Starter
fenix's Avatar
Well I'm going to get thar wheels and do the hub swap and I deal withthat later thanks a lot for all uor help guys I really appreciated this is a great place full of nice people
fenix is offline
post #20 of 27 (permalink) Old 12-01-2010, 06:09 PM
Send a message via AIM to Stocker
+1
I did the hub swap with 17x9/10.5 deep dish Bullitts on mine and they stick out .5-1". Don't like it at all, then again my tires don't cover them like I thought they would either. If I were to do it again I think I'd just give Brad(?) a shoutout and have some deep dishes that still tuck under the fender and deal with the 4.25 bolt pattern.
1991 LX Thunderchicken
4 wheels/tires, A motor/ transmission, few seats and gauges
Yep, she's got it all
Stocker is offline
post #21 of 27 (permalink) Old 12-01-2010, 07:29 PM
1995 cougar xr7's Avatar
definatly thats what i did first to my cougar
1995 cougar xr7 is offline
post #22 of 27 (permalink) Old 12-01-2010, 09:08 PM
Posted a link for wheels that fit our cars. ADR, Stern and RSL wheels.
www.maxspeedperformance.com
I ordered 2 sets yesterday...18inch, 5x108, +38 offset about a dozen diff styles, with three or four diff finishes, including all chrome.
just an fyi...
delz05 is offline
post #23 of 27 (permalink) Old 12-10-2010, 07:25 AM
R8D-XXX's Avatar
I did the hub swap and the 05' up wheel offsets is what you want. I have 18x9 in front with 36mm offset and 18x10 in back with 45mm offset and I am perfectly even with my fenders in front and back.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #24 of 27 (permalink) Old 12-15-2010, 12:11 PM
MAMN12 Posse Member
JeffTBird93's Avatar
Same with me, but the wheels I got have a 30/40 offset. Barely noticeable.
I don't see how anyone can consider this a hard upgrade. The hardest part for me was finding someone to press the new hubs and bearings into the rear spindle in a timely manner, and redrill the Tbird rotors (I've since upgraded to Cobra's). It's pretty basic work other than that.
~Jeff
*signed off
JeffTBird93 is offline
post #25 of 27 (permalink) Old 02-12-2011, 10:26 AM
hey, if you go to supercoupeperformance.com they have a pretty good selection of wheels that fit the 4.25x5 bolt pattern....i got a lot of parts from them and they are really good!!!
97 MD SILVERSTREAK is offline
post #26 of 27 (permalink) Old 02-12-2011, 01:24 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
I didnt realize my 99-04 Bullitt wheels stuck out any. I was always under the impression that the offset on 05+ wheels made them sit in even further than 99-04. The reason I think this is that I have seen 05+ Bullitts on SN95 mustangs and it looks ridiculous because the wheels are so far in.
-Rob
Rob is offline
post #27 of 27 (permalink) Old 02-12-2011, 01:56 PM
I think SN95 bullets or any other 17x8 30mm offset wheel looks great on these. Totally flush with the fenders FTW
