mustang hub swap - TCCoA Forums
post #1 of 21 (permalink) Old 02-14-2011, 09:47 AM Thread Starter
tehsilver95lx's Avatar
mustang hub swap
I've been looking and i cant find a link can someone help me?
Beater lx,current mods: cold air,drilled and slotted rotors,glass pack muffler. Scrapped
Teal terror 94...trans slip and a fram air hog filter!
94 Sc :Cobra R hood,96-97 Front lights,3.73 Trac Lok,1" Raised top,5% OD Blower Pulley,CAI,Removed resonator,Gutted cats,No mufflers. "It roams around in a open loop speed density tune. killing small children and raping helpless mothers at night."
....THAT DOES NOT MATTER!....
tehsilver95lx is offline
post #2 of 21 (permalink) Old 02-14-2011, 09:53 AM
Banned
91bluecoupe's Avatar
Try this link.
I just completed the swap a couple of months ago.
http://forums.tccoa.com/showthread.p...ight=sn95+swap
http://members.tccoa.com/dlf/Article.html
http://forums.tccoa.com/showthread.php?t=133210
91bluecoupe is offline
post #3 of 21 (permalink) Old 02-14-2011, 10:11 AM Thread Starter
thanks bro,now i want to do the 93 cobra fan blades what troubles do you think i would run in to if any the rims are 17 x 8.5 bolt pattern 4 x 4.25 and then the off setting /backspacing +26mm / 5.74
post #4 of 21 (permalink) Old 02-14-2011, 10:56 AM
Banned
I am no pro for sure.
IMHO:
But I do not think those wheels were intended to work with any big brake combos on heavier cars.
Remember they are 4 lug and that you have a much heavier car(Tbird 3800#) than the mustang(3000#) I do not think it is something that most MN12 owners have worked on as a upgrade at all.
post #5 of 21 (permalink) Old 02-14-2011, 10:58 AM Thread Starter
i know one guy got the wheels remachined to fit the stock pattern...
post #6 of 21 (permalink) Old 02-14-2011, 10:59 AM
Banned
Almost anything can be done if you work at it hard enough. We just have to ask ourselves do I want to spend alot of money on this or do I want to look at other options.
Personal taste completely.
Safety first!
post #7 of 21 (permalink) Old 02-15-2011, 02:30 PM
MAMN12 Posse Member
JeffTBird93's Avatar
There needs to be a hub swap sticky that covers everything. It's discussed often enough.
~Jeff
*signed off
JeffTBird93 is offline
post #8 of 21 (permalink) Old 02-15-2011, 05:07 PM
So you want to hubswap to the mustang bolt pattern only to use a wheel that wont fit either hub?
post #9 of 21 (permalink) Old 02-15-2011, 06:07 PM
pendejo
druggles85's Avatar
I don't think we can do a Fox mustang hub swap... All the hub swap information is for 94 and newer SN95 models.
I thought some fox mustangs were five lug though, maybe similar wheels are available in a five lug pattern? Personally I keep thinking about Mark VII LSC Turbine rims, I like them but I don't think they'd suit a Cougar.
Last edited by druggles85; 02-15-2011 at 06:15 PM. Reason: changed "94+ SN95" to "94 and newer SN95" for clarity
druggles85 is offline
post #10 of 21 (permalink) Old 02-15-2011, 07:19 PM
The SVO and Cobra R were the only fox Mustangs with 5 lug
post #11 of 21 (permalink) Old 02-16-2011, 09:23 AM
MAMN12 Posse Member
What do people use when they hubswap the Fox's to 5-lug? 94+ parts? I've seen it done several times. I wouldn't imagine they're using SVO or R parts. Just curious...
~Jeff
*signed off
post #12 of 21 (permalink) Old 02-16-2011, 10:17 AM
um fox cars dont use a hub/bearing assembly on the front, they have spindles and the wheel bearing goes in the rotor
doesnt the thunderbird's fan blade factory wheels look like the 93 cobra's rim anyways? similar design at the least even if its only 15" instead of 17"
if you are taking 93 Cobra R, those are 94-95 Mustang GT wheels painted black with a chrome 93 pony rim center cap, those are on the 5x4.5 bolt pattern and wil work
2nazty is offline
post #13 of 21 (permalink) Old 02-16-2011, 10:23 AM
hub swap
fox guys use Lincoln parts from a mark 7 or a mustang SVO (same parts I believe) on the front and then I think typically they use ranger or aerostar axles and brakes on the back
MN12 chassis guys can use 94-04 mustang front brake components (I think 89-92 need to swap spindles as well, 93-97 just the hubs and brakes) for the rear you can use the 99-04 SVT mustang rear hubs, I think you still have to retain the t-bird brake calipers and use a adapter bracket to position them right over the 99-04 SVT cobra rear rotors
2nazty is offline
post #14 of 21 (permalink) Old 02-16-2011, 10:50 AM
MAMN12 Posse Member
This I know...I'm running FR500's right now. I was just curious about the Fox stuff.
You are correct on the rest of your info. You can also just have your stock rotors redrilled to the new pattern.
~Jeff
*signed off
post #15 of 21 (permalink) Old 02-16-2011, 01:25 PM
The Mark VIII/Aerostar setup is the old school method, most just swap to SN95 spindles and complete rear axle now a days.
post #16 of 21 (permalink) Old 02-16-2011, 05:20 PM
pendejo
druggles85's Avatar
Sorry if I was misunderstood, I was just trying to point out that the mustang hub swap is for SN95 models and the op wanted to swap 4 x 4.25 bolt pattern wheels off a fox mustang.
post #17 of 21 (permalink) Old 08-08-2014, 12:07 PM
13HemiRam's Avatar
Great thread!
13HemiRam is offline
post #18 of 21 (permalink) Old 08-08-2014, 12:27 PM
Wrong. Only the differential side was changed to 31 spline.
post #19 of 21 (permalink) Old 08-08-2014, 12:39 PM
13HemiRam's Avatar
Yeah I realized that. That's why I edited my post lol. On a side note that seems like a dumb move on fords part..one side is stronger than the other
post #20 of 21 (permalink) Old 08-08-2014, 12:46 PM
It would have been sweet for us if Ford did the outers in 31 spline, only upgrade there for Cobras/MN12s are the ludicrously expensive level 5 hubs from driveshaftshop.
post #21 of 21 (permalink) Old 08-08-2014, 05:47 PM
ogbird95's Avatar
yeah If You WantThe 93 Cobras, Find A MachineShop Nearby That Is Willing To Fill And Drill A Set Of Wheels. Make Sure There A Respected Shop. The Company I Used Was Called Wheel Concepts . The Charged Me 60 Per wheel
ogbird95 is offline
