225 50 16 on front? - TCCoA Forums
post #1 of 7 (permalink) Old 02-22-2011, 01:48 PM Thread Starter
conquistador's Avatar
225 50 16 on front?
I have 225/60/16s all around my car at the moment. The front two tires will need replacement soon and I found a couple Goodyear Eagle 225/50/16s for free on craigslist. I picked them up yesterday & they are in good shape with a substantial amount of tread left on them. It will only be temporary until I get another job (or they renew my contract at my old one, been 3 weeks waiting on them).
I know that they will fit fine, but they look to be about 1" in diameter smaller & I wonder if they will look bad or will they look decent. Has anyone else here ever done this?
conquistador is offline
post #2 of 7 (permalink) Old 02-22-2011, 02:57 PM
Banned
91bluecoupe's Avatar
Keep them on the front and it will look fine.
91bluecoupe is offline
post #3 of 7 (permalink) Old 02-22-2011, 03:53 PM
jco1385's Avatar
they are about 1.75 inch shorter.
i agree. keep them up front and all should be good.
1996 Cougar - 2004 3.9L 4R70W
jco1385 is offline
post #4 of 7 (permalink) Old 02-22-2011, 09:19 PM
fast Ed's Avatar
Not sure about your math. A 225/60/16 will be roughly 26.6" diameter, 225/50/16 will be roughly 24.9". MN-12s have huge fender openings, IMO that size will look like azz on the car.
Check the load index on the tires too, you may have to put quite a bit of air pressure in them to have enough load capacity for the front as well. Typically a 225/60/16 will be a 97 or 98 load index, and the 225/50 will be 92, unless it is an XL tire. That's a difference of over 250 lbs. capacity per tire. Not trying to be an alarmist, just want to make you aware ...
cheers
Ed N.
88 T-Bird Turbo Coupe 5-speed
fast Ed is offline
post #5 of 7 (permalink) Old 02-22-2011, 10:23 PM
If you have ABS it won't work right having staggered sizes, it won't handle well either
post #6 of 7 (permalink) Old 02-23-2011, 01:18 AM Thread Starter
no abs here.
I'm worried about the big gaps in the wheel wells too.
Thanks for the load index info, I will check that first thing!
post #7 of 7 (permalink) Old 02-23-2011, 12:21 PM
jco1385's Avatar
my math was wrong. i fixed it.
jco1385 is offline
