What thickness spacer needed for a lincon ls spare? - TCCoA Forums
post #1 of 5 (permalink) Old 03-24-2011, 06:18 AM Thread Starter
On Probation
blown96bird's Avatar
I know that I will need a spacer for the lincoln LS Spare I need to know what thickness of a spacer I will need.
blown96bird is offline
post #2 of 5 (permalink) Old 03-24-2011, 07:42 AM
Have you tried test fitting it if you have it? With it being pretty narrow, it is possible that a spacer is NOT needed like is needed with a fill sized LS/new age TBird wheel.
Bangster is offline
post #3 of 5 (permalink) Old 03-24-2011, 08:56 PM Thread Starter
On Probation
The wheel needs spacers to keep the lug nuts from bottoming and the wheel not being tight to the hub.
post #4 of 5 (permalink) Old 03-30-2011, 09:09 PM Thread Starter
On Probation
I found out that I did not need a spacer. The lug nut that you need are door man part numbers 611-226 for plain short lugs or 611-229 for the stainless steel covered short lugs. f
post #5 of 5 (permalink) Old 03-30-2011, 09:22 PM
i posted that to your other thread a month ago didn't i?
Bangster is offline
