Backspacing for a big little setup with hub swap - TCCoA Forums
post #1 of 4 (permalink) Old 03-28-2011, 08:06 PM Thread Starter
Send a message via AIM to fordsvtbird
I have the mustang 4.5 bolt pattern hub swap and want to change my big little drag setup to something new. I want to know what other guys are running that have a hub swap for the rear offset and if anyone has run 17's on the front to clear their 13 inch rotors without using 1in spacers. Thanks!
fordsvtbird is offline
post #2 of 4 (permalink) Old 03-29-2011, 03:16 PM
MAMN12 Posse Member
JeffTBird93's Avatar
Blown38 is running a 17" skinny on the front that will clear big brakes.
~Jeff
*signed off
JeffTBird93 is offline
post #3 of 4 (permalink) Old 04-03-2011, 07:57 PM Thread Starter
Ok, thanks!
post #4 of 4 (permalink) Old 04-03-2011, 09:59 PM
driller's Avatar
I have 15x8 Weld Draglites with 5.5" backspace on the rear with the Cobra rotor and Ed's bracket. I had to grind the caliper just a wee bit.
I have 17" Cobra aluminum spares for now to run on the front and they clear the Cobra brakes without using a spacer.
driller is offline
