Looking for new rear tires - TCCoA Forums
post #1 of 33 (permalink) Old 05-03-2011, 08:03 PM Thread Starter
Earl's Avatar
Well, I have 245/40/18 General Exclaim UHP's on the front of the car....they're great, and I would get a set for the rear, but, unfortunately, General decided to discontinue the Exclaim UHP, which is a shame.
The NITTO drag radials that I threw on back in September, are now in dire need of replacement, as I have registration renewal / state inspection next month, so the cock is ticking...
When I bought the car, it had 275's on it...they had stretched sidewalls, which looked funky...
So I am thinking AT LEAST a 285 tire is the way to go...
I really like the look of the BFGoodrich g-Force T/A .... This car has had mismatched front/rear tires as long as I have owned it, so why change tradition now?
Basically I guess I am asking, what are your opinions on 18x10 tires "no more than a 40% profile"
thanks
Earl is offline
post #2 of 33 (permalink) Old 05-04-2011, 05:36 AM
Dusty's Avatar
You might try tirerack, they say they still have a couple 275/40-18. I am running them on 10 inch wide 18s and they look fine.
http://www.tirerack.com/tires/TireSe...er=18&x=12&y=9
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #3 of 33 (permalink) Old 05-05-2011, 01:21 PM
MAMN12 Posse Member
JeffTBird93's Avatar
I'm running a 275/40/18 on a 10" wheel and the tires are pretty much even with the edge of the wheel. I'll be replacing mine sometime this year since they're getting pretty worn. I'm planning to see just how wide I can go. I know a few people here have success with a 295, but I'd love to do a 305 or 315 just for the meaty look.
~Jeff
*signed off
JeffTBird93 is offline
post #4 of 33 (permalink) Old 05-05-2011, 01:31 PM
In the rear I'm running 275/40/18 on a 9" rim and 285/40/18 NT05R's on the same 9" rims.
They both fit and look amazing.
For an 18x10" rim I'd go with a 285 minimum and, like Jeff, I would prefer a 305 or 315.
post #5 of 33 (permalink) Old 05-05-2011, 01:48 PM Thread Starter
Earl's Avatar
Thanks for the advice, I'm gonna go with the Above mentioned BFG's in a 295....as for wider, currently I Have a 305 on my 18x10....I say go for it if you can find 'em
Earl is offline
post #6 of 33 (permalink) Old 05-05-2011, 05:29 PM
MAMN12 Posse Member
305/xx/18? I wouldn't mind going a little taller if I have to.
~Jeff
*signed off
post #7 of 33 (permalink) Old 05-05-2011, 06:26 PM Thread Starter
Earl's Avatar
I have 305/40/18 NITTO drag radials currently....
Earl is offline
post #8 of 33 (permalink) Old 05-05-2011, 10:27 PM
TCCoA Wheel Guru
275-40-18 fits perfect on a 10" wheel. Some mfr's run a lil narrow but still dont have that stretched sidewall and if it did I would change them out with another mfr.
285-40-18 is still a good size for a 10" wide wheel.
Anyone running our 18X10 Bullet with a 295MM+ tire, I would like to know what kind of Clearance you have with the shock assembly and bracketry.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #9 of 33 (permalink) Old 05-05-2011, 11:20 PM Thread Starter
Earl's Avatar
Brad
When I bought the car it had 275 dunlop dirriza's on the rear...they where stretched and looked horrible...so they must run a bit narrow.
As for 295+ and clearance issues....I currently have 305/40 NITTO drag radials are there are NO clearance issues...of course, I am running stock SC springs on the car, so that helps, obviously.
Slammed there was no way I could run anything that large/wide.
When the car was slammed a 275 would rub on the inner body above the shock mount when the suspension compressed over bumps. 285's that I had before the drag radials, of course, rubbed even more
Earl is offline
post #10 of 33 (permalink) Old 05-06-2011, 08:29 AM
MAMN12 Posse Member
I believe the 10" Bullet wheels are a different offset than I'm running if I remember right. My 18x10's are +40.
~Jeff
*signed off
post #11 of 33 (permalink) Old 05-06-2011, 06:29 PM
Dusty's Avatar
I have to agree with Brad, I am running the 275/40-18 UHPs on a 10 inch rim with 1" drop with air bags and rolled fenders, show me the streched sidewall:
I am sure it will no change your opinion since some people think wider is always better. Kind of reminds me of people who run air shocks at max to fit wide wheels with all the weight on the front of a rear drive car.
Brad
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #12 of 33 (permalink) Old 05-06-2011, 10:51 PM Thread Starter
Earl's Avatar
I was speaking specifically about Dunlop Dirrizza 275's...they MUST run narrower than other 275 tires, since they where very clearly stretched when I bought the car.
General Exclaim UHP on the other hand, are a completely different animal, and I like them...I have them on the front, and, while they unfortunately have been discontinued, my boss tracked down a set for me...I can't remember if I am getting a 285 or a 295....but they should be here Tuesday...And your silver car is very nice....actually, you are the reason I went with General UHP's and I have been very impressed with them.
Earl is offline
post #13 of 33 (permalink) Old 05-08-2011, 08:10 AM
Dusty's Avatar
I see now what you are saying. I have also seen pictures with the 275/40-18 Cooper Zeon tires on the 10 inch bullits that looks fine like the UHPs.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #14 of 33 (permalink) Old 05-08-2011, 09:51 AM
R8D-XXX's Avatar
I have 285/40/18 Nitto 555's on my 10" wheels and think they are a great fit. The tires are just barely wider than the wheel itself.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #15 of 33 (permalink) Old 05-09-2011, 09:18 AM
MAMN12 Posse Member
Ha...that's not stretched...there's VW kids around here running 205's on 9.5" wheels. Idiots.
~Jeff
*signed off
post #16 of 33 (permalink) Old 05-09-2011, 10:30 AM
LOL
Now that's s t r e t c h e d ! ! !
I'd like to see a picture of that.
post #17 of 33 (permalink) Old 05-09-2011, 12:35 PM
MAMN12 Posse Member
I'll throw some up later. They do it so they can go lower without having fender problems...regardless of the safety issue. One of them told me that it's fine because "pro drifters do it".
~Jeff
*signed off
post #18 of 33 (permalink) Old 05-09-2011, 12:53 PM
I see alot of E30 BMWs like that too
post #19 of 33 (permalink) Old 05-09-2011, 07:41 PM
MAMN12 Posse Member
LOL
~Jeff
*signed off
post #20 of 33 (permalink) Old 05-09-2011, 07:58 PM
Oh Lord!
Thanks for obliging my request.
I just landed in Atlanta. God Bless airport Wi-Fi.
Next stop - Home in Charlotte for a 36 HR layover before flying to Washington state.
post #21 of 33 (permalink) Old 05-09-2011, 10:17 PM Thread Starter
Earl's Avatar
How does the bead even seat correctly? Wouldn't the tire blow out if you hit any sort of bump in the road?
That purple wheel is very ugly....and WHY OH WHY would they do that?!?!?
And what self respecting tire shop would even mount those?
Now I'm probably going to notice this and actually see it in person can't un-learn or un-see some things :puke:
wow.
Earl is offline
post #22 of 33 (permalink) Old 05-11-2011, 01:49 PM
CEO, WT Club
GODSPEED's Avatar
Earl, I just posted up a fell set of tires, might work out for ya, check them out...
http://forums.tccoa.com/showthread.php?t=135150
-Joel
Previous MN12s:
GODSPEED is offline
post #23 of 33 (permalink) Old 05-11-2011, 02:51 PM
MAMN12 Posse Member
^ Great price!
Same sizes I'm running on my staggered wheels.
~Jeff
*signed off
post #24 of 33 (permalink) Old 05-12-2011, 11:36 AM
Banned
91bluecoupe's Avatar
Here is my right front tire.
I have 275/40/17 in all 4 places.
No problems and they look tough.
91bluecoupe is offline
post #25 of 33 (permalink) Old 05-27-2011, 08:58 PM
xgrimlinex95tbird's Avatar
Stretched tires are really big in the import/drift world. I print and cut custom vinyl for a drift club in Tulsa and the best drifter in the bunch has tires stretched like that. No special mounting required. He runs an LS2 engine in a 95 240sx and if pulling a drift at 70 won't unmount the rear tires I would say they can hold up to almost anything.
1995 Thunderbird LX 4.6l sohc - lots of plans but short on time and cash
xgrimlinex95tbird is offline
post #26 of 33 (permalink) Old 05-27-2011, 09:06 PM
Roadrunnner's Avatar
Thats not even on the bead of the rim. There is a gap between the bead and the sidewall. The acuall bead is of the tire is lower that the bead of the rim
Will
Roadrunnner is offline
post #27 of 33 (permalink) Old 05-27-2011, 09:36 PM
TCCoA Wheel Guru
Looks like ass.
I dont know what the drifting advantages would be in running a tire WAY too narrow for a given wheel width, but there is deff not a street advantage I can think of.
Brad
1990 & 1994 SC's
cudaz101 is offline
post #28 of 33 (permalink) Old 05-27-2011, 10:35 PM Thread Starter
Earl's Avatar
WHOA 275 on the front wheels of an MN12? I ran 255's on mine a year ago, and there was major rub on the inside...it was still slammed back then, which wasn't helping, but that is definately the widest I have heard of on the front of one of these...could the SN95 hub swap having a differing offset from the bird's stock setup be helping you a bit there?
Earl is offline
post #29 of 33 (permalink) Old 05-31-2011, 11:31 AM
Banned
Yeah I guess it must be the SN95 hub swap because I have no rub at all.
post #30 of 33 (permalink) Old 05-31-2011, 01:53 PM
It's the SN95 offsets, more positive ones like the ones made for these cars and S197's will cause clearance issues with the knuckles. My next front tire will be a 285/40
