P235 60r16 - TCCoA Forums
post #1 of 7 (permalink) Old 09-19-2011, 12:02 PM Thread Starter
CometGSR's Avatar
P235 60r16
Has anyone every tried this tire size? The Michelin I want doesn't come in P225, so I figured I would ask in case someone has looked into it. The wheels I am using are 6.5" wide.
Thanks!
-=James
1995 Ford Thunderbird V8
SCT Tuned by Amercian Motorsport, Mustang PBR, FRPP 3.73 gears, Modified Trak-Lok, Steeda UDP, K&N Panel, 1990 SC Seats, 2.5" Single Exhaust/Magnaflow Hi-Flow Cats, Michelin Pilot Sport A/S +, Windstar wheels, RichardM Intake, Kenwood KDC-HD552U HD Radio, 2800 stall DirtyDog Marauder TC, J-MOD, 2002 Grand Marquis transmission, DynoTech Driveshaft, AeroForce Interceptor Scan Gauge, Griffin Super High Capacity Radiator, 180* Thermostat, Cobra steering wheel, 6000K HID, Clear Corners Getting a makeover Spring 2015
http://www.fordthunderbird.net - For Pics and more!
CometGSR is offline
post #2 of 7 (permalink) Old 09-19-2011, 12:25 PM
96PRLBRD's Avatar
My tires are P235/55R17 as you know and there is no rubbing. I was concerned about the width being maybe a bit too much, but there is just barely enough clearance with the top ball joint on the front UCA... and I have 7" wide rims.
If you plug in the numbers my tires versus yours here http://www.miata.net/garage/tirecalc.html you'll see that your tires are 0.1 inches shorter (height/diameter) so you shouldn't have a problem.
--> My most recent pics <--
96PRLBRD is offline
post #3 of 7 (permalink) Old 09-19-2011, 04:52 PM Thread Starter
CometGSR's Avatar
Yeah, I didn't see your post until I started this thread. I used the same site to figure it out.
Awesome!
-=James
CometGSR is offline
post #4 of 7 (permalink) Old 09-22-2011, 10:09 PM
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
I run 245/50/16 Bridgestone Potenza's on a 16x7 rim with no rubbing issues. I am pretty sure those would fit on a 16x6.5 rim...
TGJ is offline
post #5 of 7 (permalink) Old 10-04-2011, 12:16 PM
ortbird's Avatar
I have that size; 235/60/16 on OEM sport wheels and they fit and work just fine.
makes the speed about 2mph faster than what the speedo shows, though
Cars: 97 Tbird 4.6 spt pkg(SOLD), 05 BMW 330Ci Perf. pkg, 03 Elantra (wife's)
ortbird is offline
post #6 of 7 (permalink) Old 10-04-2011, 05:36 PM
Roadrunnner's Avatar
I run that same size myself. Fuzion zr1's
Will
Roadrunnner is offline
post #7 of 7 (permalink) Old 10-04-2011, 09:00 PM
Allan's Avatar
I bought my old '92 SC with the 235/60R16 size tires on it. No rubbing but the tires weren't as low-profile looking as the stock 225 size. They filled up the wheelwells but, to me, they looked a little big.
92 Sport -5.0L
Rolling on 17s, long tubes and a "To-Do" list
97 Sport -4.6L
Rolling on 17s, SOLD but not forgotten
15 Scat Pack -M6
Rolling on 20s... like that means something
Non-Official Parts Hoarder
Cars, guitars, cigars, etc.
Allan is offline
