17x9 + Lowered Tire Question...... - TCCoA Forums
post #1 of 12 (permalink) Old 02-11-2012, 11:58 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Yes I am going to be one of "those" guys and ask a question that seemingly is answered via the SEARCH function. But I have searched extensively and haven't found my combo and therefore my answer. I got a new suspension for Christmas, I also got new wheels last October, Consists of:
17x9" Cobra R Replicas, perhaps Dante Design (it's got the fake snake in the center caps)
Tokico Fronts
Bilstein Cobra Vert Rears
1.75" Drop Vogtlands
QUESTIONS:
With almost 2" of drop will I still be able to run 255/50/17's all around without a rubbing issue? Either with the UCA or the wheel well?
If UCA rubbing is an issue, is using say a 4mm spacer safe/good idea?
With said 17x9's is running a 275 in the rear doable without rolling or modifying fender.
Thanks in advance!!!
C.Hill
'97 Laser Red T-bird w/ Option 66S - 125,000 miles, stock except for 3.73s Best ET 15.6 @ 88.3
'94 Electric Red T-bird LX V-8- 212,000 miles- SOLD
2005 Ebony Black Excursion Limited 6.0 Diesel STUDDED
"Thinking is the hardest work there is, which is the probable reason so few engage in it."
- Henry Ford
"Opportunity is missed by most people because it is dressed in overalls and looks like work."
- Thomas A. Edison
http://www.tailofthedragon.com <---- A test of driving ability and nerves.
stangboy7 is offline
post #2 of 12 (permalink) Old 02-12-2012, 12:01 AM
Tokico Fronts
QUESTIONS:
C.Hill
Not sure about the 275 rear rubbing or not... however I run 255/50/17 all around and the only thing you have to do to make them fit is clearance the upper ball joint excess, the knob that protrudes through the spindle. It doesn't hurt anything, don't fear removing it.
post #3 of 12 (permalink) Old 02-12-2012, 09:24 AM
392Bird's Avatar
275x40x17 fit on the rear of mine fine, but during the 1st hard launch, it squated and the edge on the fender cut the side of the tire near the tread.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #4 of 12 (permalink) Old 02-12-2012, 03:01 PM
BlkBrd95's Avatar
Send a message via MSN to BlkBrd95
255/45/17 on mine and i have no rubbing issues.
2001 Ford F-150 Supercrew
1995 Thunderbird LX
BlkBrd95 is offline
post #5 of 12 (permalink) Old 02-12-2012, 03:03 PM
Offset? That's a key player in weather they'll rub the fender(rear) or spindle(front).
You can cheat a bit in the rear with the air lift bags as well.
post #6 of 12 (permalink) Old 02-13-2012, 09:49 AM
255/45/17s is what I run in the rear, to run that in the front I would have to whack off the bottom of the upper ball joint like mentioned. Still a little narrow for a 9 inch wheel but looks okay, better than the 245/45/17 I currently run in front. When those get worn, the 255 go in front and something a little wider goes in the rear.
I have tokico lowering springs.
Bangster is offline
post #7 of 12 (permalink) Old 02-13-2012, 10:33 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
They are in storage, I will have to check this next week.
C.Hill
- Henry Ford
- Thomas A. Edison
post #8 of 12 (permalink) Old 02-15-2012, 09:49 AM
I have the 17x9 Dante Cobra R's on my '97 with the 0.75" drop Vogtland springs. Running 255/45-17s in front required a 4mm spacer. Running 285/40-17s in the rear required rolling the fender lips. As experienced by 392Bird, I gouged a tire before realizing that had to be done. Preumably even more necessary with a bigger drop.
MikeB
1997 Thunderbird Sport
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #9 of 12 (permalink) Old 02-16-2012, 06:03 PM
TCCoA Founder
Sir William's Avatar
I have Eibachs with the 17x9 03 Cobra wheels from Brad and I run 255/50-17s all the way around on it. I don't hit the knuckle, but I do rub the lip in the back a tiny bit on compression. I added airbags in the springs which took care of that.
God Bless and Fly Low!
Sir William
TCCoA Founder
97 Thunderbird LX - Smoothed
99 Expedition Eddie Bauer
04 Grand Cherokee Overland
Sir William is offline
post #10 of 12 (permalink) Old 02-24-2012, 01:03 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Ok so I'm a dummy, i've never really measured rims before. I measured from the lip on the back of the rim to the back side of the hub and it seemed to be 6". And from the front of the hub to the front lip was 3.5" does that help anyone determine the offset? or is that just the backspacing? Like I said I have never measured them before and don't know wtf i am doing.
They came off of a Mark viii. And the guy who was running 275/40/17's in back and 245/45/17's in front IIRC
- Henry Ford
- Thomas A. Edison
post #11 of 12 (permalink) Old 02-24-2012, 01:33 PM
stangboy7,
The back spacing on the Dante 17"x9" wheel is 5.94", and the offset is +36mm.
MikeB
5.0L-2V PI S/C
540 RWHP / 492 RWTQ
11.28 @ 123 MPH
MikeB is offline
post #12 of 12 (permalink) Old 02-24-2012, 03:48 PM Thread Starter
shaken, not stirred
stangboy7's Avatar
Originally Posted by MikeB View Post
stangboy7,
HAHA THANK YOU!!!
But now with the known offset and backspacing....anyone have any suggestions for a 1 3/4" vogtland drop?
Because I would really love to have a 255 on the front and 275/285 on back....
Thanks again!!!
- Henry Ford
- Thomas A. Edison
