Wheel Stud Size - TCCoA Forums
post #1 of 9 (permalink) Old 04-03-2012, 12:09 AM Thread Starter
TGJ
Baddest N/A NPI in Canada
TGJ's Avatar
Wheel Stud Size
Does anyone know what the factory length and size of the wheel studs on these cars are? Is it possible to get ones that are .5" longer. Getting the car ready to be plated, I wrecked a stud so I need to have it replaced. When I go to the track, it would make my life a lot easier if the fronts were .5" longer.
TGJ is offline
post #2 of 9 (permalink) Old 04-03-2012, 12:40 AM
M12-1.5 is stock I think, and they are 34mm long OEM, which is almost 1.5" long (if my reference is correct lol)
Jegs sells 2.5" and 3.25" long studs that same size: http://www.jegs.com/p/JEGS-Performan...24592/10002/-1
~Rick
TCCoA Sig
post #3 of 9 (permalink) Old 04-03-2012, 06:37 PM
tbirdtess's Avatar
Hello
You ever get to Niagara Falls?
I have a pile of of wheel studs. Both fronts & rears.
I use aftermarket wheel studs.(1/2 - 20) & 1" nuts
Paul [email protected]
351W 2bbl.
C-4 Auto
3.90 open rear
tbirdtess is offline
post #4 of 9 (permalink) Old 04-04-2012, 11:30 AM
Originally Posted by tbirdtess View Post
Hello
It's funny you brought that up. I have a whole pile from front hubs and I just figured they would be they same as the rears - THEY AREN'T.....
I'm like WTF, two different size wheel studs?!? Both M12-1.5, but the knurling on the end are different sizes.
Also, to the OP, I just want to Advanced to get some replacements for my Mark VIII and they have different lengths in stock.
~Rick
TCCoA Sig
post #5 of 9 (permalink) Old 04-04-2012, 12:07 PM Thread Starter
TGJ
TGJ's Avatar
I have been to Niagara Falls. Are the rears longer than the front? It is the front ones that I need to be longer. Unless I change both my street and racing rims which I do not want to do, I need to stick with the stock thickness. I will check out some of the auto parts stores. Thank you.
TGJ is offline
post #6 of 9 (permalink) Old 04-04-2012, 02:20 PM
No, they are all the same length, but the knurling (the part that presses into the hole of the hub) are different sizes on the front and back. The rear ones are a lot fatter than the front ones. I'll try to get you a pic once Daniela gets home with her good camera phone
~Rick
TCCoA Sig
post #7 of 9 (permalink) Old 04-11-2012, 05:34 PM
Rob
Rob's Avatar
Send a message via AIM to Rob
FWIW, I went to 1/2-20 when I did the hub swap so my rear lug nuts would match the fronts.
-Rob
Rob is offline
post #8 of 9 (permalink) Old 04-20-2012, 04:21 PM Thread Starter
TGJ
TGJ's Avatar
Were you able to get them with the right knurling or did you have that drilled out as well?
TGJ is offline
post #9 of 9 (permalink) Old 04-20-2012, 06:13 PM
This is the rear wheel stud and Dorman link (part # 97038.1):
http://www.dormanproducts.com/p-23034-970381.aspx
Here is the front wheel stud and Dorman link (part # 98519):
http://www.dormanproducts.com/p-33438-98519.aspx
~Rick
TCCoA Sig
