Stepping up to 315's - TCCoA Forums
post #1 of 7 (permalink) Old 04-24-2012, 06:37 PM Thread Starter
Send a message via AIM to Red97Tbird
I'm stepping up to 315's on the back once my 285's wear out.
4.6 explorer motor,Water meth injection, V1 Vortech, 3.48 pully,BBK 78mm, Dirty Dog 9.5 converter 3500 stall, RobertP built trans, 8.8 rear with trac lock, 3.73 gears, BrainCoating manifolds, Dual 2.5" exhaust.
Red97Tbird is offline
post #2 of 7 (permalink) Old 04-24-2012, 06:49 PM
Which 315's? And what rim size are you running now?
I was thinking about stepping up from 18"x9" to 18"x10" on my rims but couldn't find a 315 that would fit. I think I need a 315/35/18? Is that correct?
It looks like TOYO is the only MFG in that size?
post #3 of 7 (permalink) Old 04-24-2012, 07:00 PM
Will 315 fit? I know my 275 on a 18x10 is tight.
97 LX
Motor and trans from 95
Working out the bugs right now.
R.I.P.
1995 Thunderbird LX. Black
BEST MOTOR TIMES
12.76 @ 105
BEST NITROUS
12.12 @ 109 mph
Stuckinkaos07 is offline
post #4 of 7 (permalink) Old 04-24-2012, 07:27 PM
315 would clear easy on my car if I had the wheels widened more
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #5 of 7 (permalink) Old 04-24-2012, 07:51 PM Thread Starter
I'm running 18x10.5's on the back right now with a 285x40x18. I will have a ways before it will rub. I am running mustang bolt patten though. Here is a pic of when I use to have 275x40x18's on the 10.5 inch wheel. Yea wasn't pretty lol. But you can see If I move the brake line I should have room.
post #6 of 7 (permalink) Old 04-24-2012, 08:08 PM
im running a mustang bolt pattern as well. When my 275 rears wear out, i wanted to get bigger, but i didnt know if they would clear, but when that time comes, ill ask under the wheels and tires section.
97 LX
R.I.P.
BEST MOTOR TIMES
12.76 @ 105
BEST NITROUS
12.12 @ 109 mph
post #7 of 7 (permalink) Old 04-27-2012, 05:25 PM
Extracted from Darren's build tread since this is a seperate, unrelated topic.
Feel free to discuss here ...
