Widest Tire - TCCoA Forums
post #1 of 4 (permalink) Old 05-12-2012, 02:41 PM Thread Starter
Widest Tire
Can someone tell me what the widest tire is that I can put on a 97 TBird Sport with stock wheels and OE tires that are 225/60/16's. Are 235/55/17's the widest while not making the speedo off too much?
TXTBird
Houston, Texas
TXTBird is offline
post #2 of 4 (permalink) Old 05-12-2012, 02:51 PM
If you're going with 17" rims I'd go 245/50/17
to match the OEM 225/60/16.
You can check sizes with this tire app. It's a great tool.
http://www.miata.net/garage/tirecalc.html
post #3 of 4 (permalink) Old 05-12-2012, 03:50 PM
Rayo's Avatar
I'm running 225/55/17 GoodYear F1 tires all around on mine..Which is almost exactly the same diameter as the 225/60/16..
IMO running more sidewall=more comfortable ride..
You could run those 235/55/17 tires..
Your speedometer will read slower then your actual speed with that size though..
Which means when your speedometer says you're going 55Mph..
You might actually be going 60Mph..
1991 Ford Thunderbird Sport
Rayo is offline
post #4 of 4 (permalink) Old 05-12-2012, 03:52 PM
SuperThunderbirdLX's Avatar
I'm not sure but I think he meant 235/55-16. Not 17.
-Daniel
SuperThunderbirdLX is offline
