18×10s - TCCoA Forums
post #1 of 8 (permalink) Old 05-24-2012, 12:27 AM Thread Starter
18×10s
I'm looking at finding some 10" wide wheels for my car currently have 8's on all 4 corners do they make them for our lug pattern? I'm running 265's in rear 245's up front and zero traction. I have some 295's I want to put on the rear but will not fit on those wheels..I would like to do this without swapping bolt pattern.I no longer have a garage I can do this in which is putting a hault on a lot of other things I want and need done..so any insight on this would be great thanks
H.O.-BIRD is offline
post #2 of 8 (permalink) Old 05-24-2012, 02:15 AM
Brad (Cudaz101) at The Custom Wheel Shop has them in the Tbird bolt pattern.
I run 18 x 9's on my car with 245 front and 275 rear; with 285 drag radials and I got plenty-o-traction.
Which tires are you running? Do you have a trac-lok (posi) rear end?
post #3 of 8 (permalink) Old 05-24-2012, 06:22 AM Thread Starter
Ive hot track loc 410's 265 3518's in rear bfg g force...and smoking the hell out of them anything more than half throttle ...it will start breaking loose at half throttle .. 272.5 Hp 287.7 tq
post #4 of 8 (permalink) Old 05-24-2012, 06:44 AM
Nice numbers. What all have you done to the car/engine?
Is it forced induction or N/A?
post #5 of 8 (permalink) Old 05-24-2012, 11:19 AM Thread Starter
N.A. mark8 pistons notched ARP head studs PI heads comp 270's beehive springs 12:1 compression....mark8 oil pan
Trick Flow plenum 75mm throttlebody C&L 80 mm mass air CAI (Mac) Kooks headers 24# injectors adjustable fuel regulator screaming demon coils and wires
Magnaflow DI / DO center mounted muffler 2-1/2 stainless all the way out to chromed stainless 3" tips
3000 PI stall, built trans, 4:10's track-loc and a dyno tune
You have a sweet setup
post #6 of 8 (permalink) Old 05-24-2012, 02:23 PM
Thank you.
... and so do you.
post #7 of 8 (permalink) Old 05-27-2012, 06:50 PM
FLPNDBRD's Avatar
Send a message via Yahoo to FLPNDBRD
them 4.10's may be the cause of it. BFG's are pretty good tires. Lower the tire pressure a little and see what happens.
You Gon Learn Today.....
FLPNDBRD is offline
post #8 of 8 (permalink) Old 06-16-2012, 07:31 PM Thread Starter
I ran them at 28 and at 25psi still having issues looking at some 295/45/18's off a lightning gonna check clearance tire hieght might actually help traction. And speedo being off a bit
