Will this fit? - TCCoA Forums
post #1 of 4 (permalink) Old 05-30-2012, 02:21 AM Thread Starter
Dutch T-Bird's Avatar
Will this fit?
I found a new set 19 inch 7.5 Alba Bank for a very nice price.
The off set of this combo is 48
Will this fit?
The Alba's I have are 19 inch
7.5
off set 35
Thanks for all your input!
clear corners, 1997 tail & corner lights, shaved trunk lid, removed fender emblems & door moldings, painted door handles, K&N conical-QSP air intake , deep tranny pan, drilled & slotted rotors, Derale tranny cooler, 19" Alba Bank and Air Ride!
Dutch T-Bird is offline
post #2 of 4 (permalink) Old 05-30-2012, 07:32 AM
R8D-XXX's Avatar
Those new Alba's you are looking at with the 48MM offset will tuck inside the car another 1/2". So as long as you aren't close to hitting anything right now and you think it will look okay, they should be fine.
pics of my car
Updated 10/14/11
13.0 @ 106.5 1.79 60ft
R8D-XXX is offline
post #3 of 4 (permalink) Old 06-04-2012, 04:56 AM Thread Starter
Thanks R8D!
post #4 of 4 (permalink) Old 06-04-2012, 10:35 PM
bagged95's Avatar
Make sure you have the clearance between the top of the spindle arm and the wheel/tire and they should be fine.... And if you dont, then you can always run spacers LOL.
bagged95 is offline
