1990 SuperCoupe 16" Wheels/1997 LX 16" Wheels - TCCoA Forums
post #1 of 6 (permalink) Old 08-19-2012, 02:10 AM Thread Starter
On the 1990 Thunderbird SuperCoupes, was there no left & right 16" wheel, like there was on the 1997 Thunderbird LX? Every place I look-up Thunderbird wheels shows a separate left and a separate right 16" wheel for the '97 LX, but lists only one part # for the '90 Supercoupes - wouldn't the swept spokes be facing the wrong way on the one side of the car with the '90 16" wheels?
Also, are there any other center caps that will fit the '97 16" wheels, besides the original ones with the holes that expose the lug nuts (I'm not a big fan of that look)? Will the center caps from the '90 16" wheels fit the '97 16" wheels?
post #2 of 6 (permalink) Old 08-19-2012, 05:20 AM
Correct, the early SC had only one rim. The spokes will face the wrong way on the opposite side.
They will physically fit but are a PITA to get off, don't ask me how I know! Maybe find the SC rims that look like the Sport rims (92? - 95), they have the notch in the face to pop off the center cap.
post #3 of 6 (permalink) Old 08-19-2012, 06:25 AM
Rayo's Avatar
I'll add to what Joe said..
The center caps from the 93-95 Thunderbird LX/89-92 Thunderbird LX Wheels will fit on 94-95 SuperCoupe Wheels & 96-97 Thunderbird Sport Wheels..
The 94-95 SuperCoupe Wheels have the notch because they use the flat center cap..
The 96-97 Thunderbird Sport Wheels do not have the notch because they use an open lug center cap..
So if you try to use the flat center caps from the 94-95 SuperCoupe/93-95 Thunderbird LX/89-93 Thunderbird LX on the 96-97 Thunderbird Sport Wheels..
You'll have a hard time getting them off without scratching the finish on the 96-97 Thunderbird Sport Wheels..
Since there's no notch on the 96-97 Thunderbird Sport Wheels..
The 89-93 SuperCoupe center caps will not fit on the 94-95 SuperCoupe,93-95 Thunderbird LX,89-92 Thunderbird LX, or the 96-97 Thunderbird Sport Wheels..
The 89-92 Thunderbird LX Vaned Aluminum Wheel center caps will fit on the 94-95 SuperCoupe,93-95 Thunderbird LX,or the 96-97 Thunderbird Sport Wheels..
The 96-97 Thunderbird LX Wheel center caps have contours that only match the 96-97 Thunderbird LX Wheel..
As far as I know the only Thunderbird Wheel from 89-97 that ever had a metal center cap was the 89-92 SuperCoupe..
1991 Ford Thunderbird Sport
Rayo is offline
post #4 of 6 (permalink) Old 08-20-2012, 12:02 PM
SuperThunderbirdLX's Avatar
I wonder how hard it would be to add a notch to each sport rim. Line them up opposite of the valve stems to give a factory look.
-Daniel
SuperThunderbirdLX is offline
post #5 of 6 (permalink) Old 03-25-2013, 10:47 PM
CrystalPistol's Avatar
Thumbs up
I have thought of doing exactly that ..... I think it'ld be easy using a dremel and cutoff wheel on edge.
CrystalPistol is offline
post #6 of 6 (permalink) Old 03-25-2013, 11:00 PM
renello79's Avatar
It is, my buddy had to do it to one of his.
Phrum Steve
http://photobucket.com/SCno1
sold, sadly
renello79 is offline
