Tire size question for 17x9 rims - TCCoA Forums
post #1 of 12 (permalink) Old 11-20-2012, 04:42 PM Thread Starter
kev0's Avatar
I have a set of 17x9 Mille Miglia MM11-2 Sport on my 95 Lx with 4 245/45/17 tires using the stock suspension. The tires look a little small to me, and I was wondering what the best recommended size would be for my particular set up. Any help will be appreciated. Thanks in advanced! -Kevin
1995 Thunderbird LX V8 (Zapdos)
-kev0
kev0 is offline
post #2 of 12 (permalink) Old 11-20-2012, 05:51 PM
245/50/17 or 255/50/17s. Those being around 27" tall fill the wheel opening nicely.
post #3 of 12 (permalink) Old 11-21-2012, 07:05 PM Thread Starter
kev0's Avatar
So, say I went with the 255/50/17s on my 17x9 rims, you don't think there would be any rubbing issues on the stock suspension of my 95 Lx?
-kev0
kev0 is offline
post #4 of 12 (permalink) Old 11-21-2012, 07:47 PM
Shouldn't be. I'm running 255/45 and while they are about 3/4" too short, there is plenty of room. The trouble will be finding a good tire in that size.
post #5 of 12 (permalink) Old 11-21-2012, 10:27 PM
I'm running 255/45/17s on 26mm offset 17x9s and am lowered 2" up front and 1.5" out back. Only rubbing I ever got was in the rear at speed over a big speed bump, once.
235s are WAY too narrow for a 9" wheel.
post #6 of 12 (permalink) Old 11-22-2012, 05:49 AM
Rayo's Avatar
Agreed..I misread what Brandon wrote..
IIRC the 17x9 Mille Miglia MM11-2 Sport have a +30mm Offset..
245/50/17's would be perfect!..I'm not sure about 255/50/17..Those might be slightly too wide and rub..
Lets see if somebody chimes in..That's running 17x9 Wheels w/+30mm Offset & 255/50/17 tires..
1991 Ford Thunderbird Sport
Rayo is offline
post #7 of 12 (permalink) Old 11-22-2012, 07:19 AM
Just a word on the 255/50/17s I have them on the rear of my bird to handle the power and it does it well with no rubbing issues at all
post #8 of 12 (permalink) Old 11-22-2012, 09:02 AM
ClintD's Avatar
running 275/40/17 on mine and only had to roll the rear wheel lip.
ClintD is offline
post #9 of 12 (permalink) Old 11-29-2012, 12:42 PM
The 245 - 45 - 17 is the typical older Mustang tire size.
Treat your MN12 with respect and don't put a Mustang sized tire on it. Any size with a diameter of approx. 26.5 - 27" is what you want.
Super Coupe Performance
513-697-6501
If it's in stock, we have it!
Bill Evanoff is offline
post #10 of 12 (permalink) Old 11-29-2012, 02:15 PM
With a 17" wheel it's impossible to find anything larger than a 255 in that height range, 26" dead is the best you can really get with 275 or 285s and what is available is dwindling and experiencing price creep.
post #11 of 12 (permalink) Old 11-29-2012, 10:29 PM
255/50/17's on all corners here, trimmed the upper control arm ball joint stud excess for clearance.
post #12 of 12 (permalink) Old 11-29-2012, 10:41 PM
Boost!!!
modularbird's Avatar
x2 my 255/50/17 fit very well in the back, and fit pretty good in the front. very slight rubbing in the back of the front wheel well, when turned as far as it can go. i would go with 245 50 17 or something similar to that size for the front, and whatever you can fit in the back.
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
