What do I need to have the Bullitt rims? - TCCoA Forums
post #1 of 10 (permalink) Old 12-26-2012, 04:45 PM Thread Starter
i have the 95 merc cougar xr7 i would like to have the 18 or 17 type on my cougar. right now i have the drum brakes in the rear but i dont mind upgrading the rear brakes to make it work it is on the list to do.
95mercxr7 is offline
post #2 of 10 (permalink) Old 12-26-2012, 04:48 PM
There's no need to upgrade brakes when switching to 17" or 18" rims.
You will need to make sure that the rims you get are in the correct Tbird/Cougar bolt pattern. Look around the Tires/Wheels forum for more info.
post #3 of 10 (permalink) Old 12-26-2012, 05:06 PM
For mustang bolt pattern you need mustang front hubs and mustang cobra (IRS style) rear hubs.
post #4 of 10 (permalink) Old 12-26-2012, 06:00 PM
There's only one way mustang bolt pattern it's the best way and only way the other way u are limited to wheel options, the rear hubs are 155 each if u need a pair let me know the front is easy by mustang front hub assemblies from 96-04 there cheap u can get the pair off eBay 75 tops
Robert
86 bird vortech s trim
10.75 @128.38
95 bird - Vortech t trim
1/8 [email protected]
10.11 @ 139.19 best mph
RobertP is offline
post #5 of 10 (permalink) Old 12-26-2012, 06:23 PM
Dusty's Avatar
You can also save the hub swaps and get the Bullitts in the Tbird pattern from the Custom Wheel Shop if they still have them. I found it cheaper than doing the Mustang pattern swap. Works with rear disk or drum.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #6 of 10 (permalink) Old 12-26-2012, 06:24 PM
Well also the rear drums are fine u just gotta redrill the drum, and your good to go
10.75 @128.38
RobertP is offline
post #7 of 10 (permalink) Old 12-26-2012, 08:09 PM
Tbird1997's Avatar
Don't forget rotors in the mustang pattern as well
-Patrick
Tbird1997 is offline
post #8 of 10 (permalink) Old 01-04-2013, 03:49 AM Thread Starter
i have a extra set of rotors and pads for the rear for my mustang. that i never used yet i was thinking on swaping out the rear drum to disk thats what i was asking. i was thinking on swaping out the drums and all to help it stop better and to look for a hub spendle setup to make it work
post #9 of 10 (permalink) Old 01-04-2013, 04:57 AM
You'd need SN95 mustang calipers to do that. You'll also have a smaller pad and non vented rotor compared to the stock MN12 rear disc setup. You'll also lose all parking brake function
post #10 of 10 (permalink) Old 01-04-2013, 12:37 PM
If he gets disk parts from a thunderbird they will work just fine, parking brake and all. I had to redrill my rear rotors for it.
