want a taller sidewall tire, maybe? - TCCoA Forums
post #1 of 30 (permalink) Old 03-17-2013, 03:12 PM Thread Starter
TwoHaggard's Avatar
i have 275/40/17s on my cobra rims. the cars lowered two imches and have air bags in rear springs. i kinda would like a taller side wall to kinda fill the gap. what size would be the next size up? does anyone think it will rub? thanks!
Project still in progress
Explorer engine, vortech v2,intercooled,bullit intake,derale power steering cooler, b&m trans cooler, oil filter relocation, cobra aluminum radiator, Walbro 255 Pump, Intrax 2in lowering springs, KYB front/back,,mark8 Driveshaft, 1.25Rear sway bar, 3:73 aluminum diff, TrackLok, Rear Diff Cover Brace, Sc Wheels 235/60s, Jmodd, Air Bags in Springs,Rear strut Bar,17in Mirror Blk CobraRs, Sc L Brackets, rear torsional load brace, kmember-frame brace, weightloss program, pbr dual pistons drilled/slotted, stainless lines , recaro seats, sct x4 DonL tuned
TwoHaggard is offline
post #2 of 30 (permalink) Old 03-17-2013, 03:20 PM
Only size I can think of that will fit a 17 is 285/40/17... I believe you need to roll the fenders to prevent rubbing since you're lowered.
post #3 of 30 (permalink) Old 03-17-2013, 03:22 PM
S4gunn's Avatar
You might not care (b/c you are looking at it from an aesthetic viewpoint) but:
Larger diameter tire = taller final drive ratio = slower acceleration.
Taller sidewall will also net you more sidewall flex and therfore potentially lost of contact patch area
-g
http://goo.gl/csaet4
S4gunn is offline
post #4 of 30 (permalink) Old 03-17-2013, 04:27 PM
Also FYI, stock tire diameter for an MN12 is about 27". A 275/40/17 is over an inch shorter than stock.
post #5 of 30 (permalink) Old 03-17-2013, 04:57 PM Thread Starter
TwoHaggard's Avatar
Hm don't know if I want to go as far as rolling fenders, I just wanted to fill up the space but don't wanna rub, more sidewall will flex more I guess but can't will em all.
post #6 of 30 (permalink) Old 03-17-2013, 05:17 PM
I agree. 285/40/17. You won't need to roll the fenders if your shocks are firm and your suspension is solid.
Plug the stock size and the sizes you're considering in to the calculator here:
http://www.miata.net/garage/tirecalc.html
post #7 of 30 (permalink) Old 03-17-2013, 05:52 PM
rushtonracing's Avatar
Here is another tire calculator. I found this one particularly easy to use, and informative.
http://www.tacomaworld.com/forum/tir...0r15-245-50r17
rushtonracing is offline
post #8 of 30 (permalink) Old 03-17-2013, 06:12 PM
Stock height for the factory 16's 225/60s come in at 26.62", the 275s come in at 25.66". That's a hair UNDER an inch shorter than stock
post #9 of 30 (permalink) Old 03-17-2013, 06:39 PM Thread Starter
TwoHaggard's Avatar
Well I used to run 235/60s on my sc rims filled up the gap very nicely by the calculator 285/40/17 is shorter but taller then the 275/40/17s I dont rub now, but since there taller should I be worried about them rubbing on the inside or outside?
post #10 of 30 (permalink) Old 03-17-2013, 06:50 PM
There are two tires offered in a 275/50R17 (27.8" diameter), but I don't know how well they'll fit if you're lowered 2". I run that size on the rear with 245/45R17's up front, but I'll be switching to 255/45R17's up front in a few weeks.
post #11 of 30 (permalink) Old 03-17-2013, 06:54 PM
Just noticed the last post.
Originally Posted by TwoHaggard View Post
Well I used to run 235/60s on my sc rims filled up the gap very nicely by the calculator 285/40/17 is shorter but taller then the 275/40/17s I rub now, but since there taller should I be worried about them rubbing on the inside or outside?
A 285/40R17 is going to be ~3/8" wider and 5/16" taller than the 275/40R17's. If you're already rubbing now, going to a wider and taller tire isn't going to help matters.
post #12 of 30 (permalink) Old 03-17-2013, 07:09 PM
jhiland32's Avatar
I'm sure everyone has posted the info you need but I had this site saved and it's pretty helpful
http://www.jekylhyderacing.com/HeightofTires.htm
Jason H.
Mods:
jhiland32 is offline
post #13 of 30 (permalink) Old 03-17-2013, 07:17 PM
Meh, mine came with 215/70/15 which were more like 26.8" tall. So there!
post #14 of 30 (permalink) Old 03-17-2013, 08:25 PM Thread Starter
TwoHaggard's Avatar
Rod those 275/50's look great but being lowered I don't think that work, I'm not saying I'm rubbing now at all I just don't want to end up rubbing if I decide to go 285/40.
I didn't mean to say I rub now, I do not rub. I need to proof read before I reply
post #15 of 30 (permalink) Old 03-17-2013, 08:51 PM
jhiland32's Avatar
I guess it's because of the cowl hood and/or the wheel/tire combination but every time I see racecougars car it just looks "shorter" than other Cougars.
Jason H.
Mods:
post #16 of 30 (permalink) Old 03-17-2013, 08:55 PM
Boost!!!
modularbird's Avatar
i run the same 275 50 17s on the rear that racecouger has and mine rub. Im only lowered 1 inch. Its not horrible, but when i have a full tank of gas and a passenger or two, its pretty bad. I need to roll my fenders.
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
post #17 of 30 (permalink) Old 03-17-2013, 09:39 PM
Rayo's Avatar
Looking at this pic..
255/45/17 should be ok..That's just slightly more sidewall, and height than what you're running now..
Maybe give you a little more of a comfortable ride..I like the stance of your car just the way it is though..
Oh..Here's a random pic of 255/45/17 tires on 17x9 rims..Just to give you an idea what it looks like..
I hope that helps..
1991 Ford Thunderbird Sport
Rayo is offline
post #18 of 30 (permalink) Old 03-17-2013, 10:14 PM
MN12s with steelies and hubcaps came with 205/70/15s and those are only 26.3" tall! So there! haha
post #19 of 30 (permalink) Old 03-18-2013, 05:23 AM Thread Starter
TwoHaggard's Avatar
255/45/17 looks like a nice combo an looks good according to that calculator
post #20 of 30 (permalink) Old 03-18-2013, 06:18 AM
I just replaced the rear tires with 255/50/17s last week. They are a closer match to "my" stock height tires and fill the wheel well a little better. My car is not lowered.
This is my car with 255/45/17s last year.
post #21 of 30 (permalink) Old 03-18-2013, 08:29 AM Thread Starter
TwoHaggard's Avatar
255/45/s look good I think, those 255/50 may rub for me since I'm lowered lookin like I may look into some 255/45s
post #22 of 30 (permalink) Old 03-18-2013, 09:52 AM
For whatever its worth I run 255/50R-17 on the rear of the "'Sleeper" no rubbing issues at all. Nice tire size to keep the rear end from doing 360s under WOT from a start.
post #23 of 30 (permalink) Old 03-18-2013, 06:20 PM
I don't see much 18's. Is there a reason for that? I'm thinking of running 18's with 245/45/18 (26.68"). What do y'all think?
post #24 of 30 (permalink) Old 03-18-2013, 08:33 PM
Dusty's Avatar
I have 245/45-18 on the front, 275/40-18 on the back.
1995 PI Tbird
1998 TA Vert
2004 Buick Regal GS
2000 Honda ST1100
1990 Mazda RX-7 2+2
Dusty is offline
post #25 of 30 (permalink) Old 03-18-2013, 09:41 PM
^^^^Got any more pics of that car?
post #26 of 30 (permalink) Old 03-19-2013, 04:28 AM
Cost and choice mostly. 18" tires tend to cost more than 17's.
See my gallery for pix of mine on 18's.
There's also many good pictures of everyone's cars in this thread.
http://forums.tccoa.com/showthread.php?t=98026
post #27 of 30 (permalink) Old 03-19-2013, 05:07 AM
Ah yeah, that's what I'm takin' 'bout. Very nice choice in that particular color green too. Bill H's black car is to-die-for. Wondering if that is about stock height.
post #28 of 30 (permalink) Old 03-19-2013, 06:51 AM
Although now that was recently in the market for 17" tires again, I found quickly how limited the choices are for the MN12 diameter and ALMOST wish I had 18s. You're pretty much stuck with either 245/50 (or 45) or 255/50 (or 45) for the 17s. The wider tires (275s and 285s) will work but they're so short I'm hesitant to run them without seeing them in person first. I almost sprung for 285/40s this last time around, but I was hesitant because I hadn't ever seen them in person and was concerned they'd look "weird" from the back, like they'd stick out from the fenders or something. (on that note, if someone with a 275/40/17 or 285/40/17 wants to take a picture from behind their car from like 100' away, I'd be grateful!)
post #29 of 30 (permalink) Old 04-10-2013, 05:35 PM
392Bird's Avatar
I would like to go 1 step farther than the 285/40/17, and try 295/45/17 MT. They call for a 9 1/2 min width wheel, but I know several guys with Mustangs and Camaros that have them on 17x9 wheels with good results.
I could use the extra heigth and width.
-----1993 Bird 5.0------
275/50/17 M&H DR on the rear
Click for Full Project
392Bird is offline
post #30 of 30 (permalink) Old 04-10-2013, 05:45 PM Thread Starter
TwoHaggard's Avatar
Just ordered some 255/45/17s for the rear ill get pictures up soon
