new rims - TCCoA Forums
post #1 of 8 (permalink) Old 06-15-2013, 07:40 PM Thread Starter
new rims
guys im about to buy these in the 17" what do you think and will they look right with the offset thingy that im not sure what it means but people say they wish they had more
http://www.tirerack.com/wheels/Wheel...All&sort=Price
1997 Thunderbird 4.6L
New paint on tops, Magnaflow high flow cat system and custom 2 - 2 1/2 Exhaust ,J-Mod and P.I. head and intake swap(performed by RobertP @ www.RobsTireAndAuto.com ) Steeda Underdrive Pulleys, Mark VIII TC, AEM dry flow air filter, Blacked out tail lights and custom painted headlights (performed by my wife) tuned by DON at http://www.lasotaracing.com/
waiting to hear theses kooks
http://www.cardomain.com/ride/391835...rd-lx-coupe-2d
swampt420 is offline
post #2 of 8 (permalink) Old 06-15-2013, 07:46 PM
Rayo's Avatar
Your offset should be fine with those wheels..The wheels won't stick out too far, or have that sucked in look either..
You may need a set of hubcentric rings though..
1991 Ford Thunderbird Sport
Rayo is offline
post #3 of 8 (permalink) Old 06-15-2013, 07:56 PM
With a 42mm offset on a 7.5" wheel they'll appear to be placed roughly where the stock wheels sit. Though I find that way too tucked in for my taste.
post #4 of 8 (permalink) Old 06-15-2013, 07:56 PM Thread Starter
hubcentric what? you just made that up right
post #5 of 8 (permalink) Old 06-15-2013, 08:18 PM
Rayo's Avatar
No..I didn't make that up..lol
Your Thunderbird hubs should have a center bore of 63.9mm..
I don't see the bore specs available for those wheels, but it does say there are centering rings included with your purchase..
I can't say for sure if the ones included will work with your hubs..Just tell TireRack what car you have, and hopefully they include the correct hub centric rings..
If they don't have the hub centric rings you need..You can always wait, and order them after you've measured your new wheels hub bore size..
Some people don't run these rings..Some people do..It helps to center the wheel on the hub, and prevents unwanted wheel vibrations..
Rayo is offline
post #6 of 8 (permalink) Old 06-15-2013, 08:23 PM Thread Starter
thanks rayo,
I just placed the order and only looked at the wheels for a 1997 TBird. so im not sure if the rings will work but I have to wait for tires any way so I will make sure everything is perfect before I intall.
with having to wait for tires what size do you guys think I should get? I don't want rubber bands or really big tires but would like a wide tire.
what do you guys think?
post #7 of 8 (permalink) Old 06-15-2013, 08:58 PM
Boost!!!
modularbird's Avatar
I like 255 50 17s myself. Good height for these cars and wide enough to get good traction. They fill the fenders well also.
Blake
1996 thunderbird lx (the silver slut)
http://forums.tccoa.com/vbpicgallery.php?do=view&g=387
modularbird is offline
post #8 of 8 (permalink) Old 06-17-2013, 02:21 PM Thread Starter
ok guys these are the tires im buying from discount tire they have them for 122. are they a good tire.
http://www.discounttiredirect.com/di...w=false&cs=255
* ok so the 255 50 r17 didn't fit on the front with out clearing the upper control arm. so I went to a 235/50/r17 on the front and 255/50/r17 on the back. but in the process they broke one my studs on the back right but they are having it repaired and I will be getting her back Monday I cant wait!!
