Hub Swap / Rear Wheel Bearing Question - TCCoA Forums
Old 07-18-2013, 03:01 PM Thread Starter
CEO, WT Club
GODSPEED's Avatar
My Bird has 54k on the ticker. I am thinking about a hubswap, and have a question about the rear bearing. When I have the hub pressed out, can I just have the new cobra hub pressed in and leave the wheel bearing as is? Only 54k, I'd rather not replace them unless I have, but also I don't want the thing falling apart on the highway. Is it okay to keep the bearing as is?
-Joel
Previous MN12s:
GODSPEED is offline
Old 07-18-2013, 05:56 PM
I don't believe you should reuse one after you remove it; the removal process does not support the bearing real well.
Timken, set 49 at RA; cheap:
TIMKEN Part # SET49 {#513058} 1.6535 Cone Bore; 0.768 Cone Width; 2.9921 Cup Outer Diam; 1.5354 Cup Width Wheel Bearing and Race Set
$26.79
Old 07-18-2013, 11:23 PM Thread Starter
CEO, WT Club
GODSPEED's Avatar
I didn't plan on removing the bearing, just the old hub, and then inserting a new hub. Bearing would stay put in the knuckle the entire time.
Previous MN12s:
GODSPEED is offline
Old 07-19-2013, 01:10 AM
coggonobrien's Avatar
replace it
coggonobrien is offline
Old 07-19-2013, 04:04 AM
Once you disturb this part its best to replace the bearing if doing a hubswap.
Old 07-19-2013, 03:36 PM
When I pressed mine out it sounded like a gun went off when the hub gave way. No way in hell I'd trust those bearings after that.
